Date/Time: Sat, 27 Apr 2024 23:58:08 +0000
Denali package 12
View Count: 324
[2022-05-13 16:28:15] |
User108811 - Posts: 1 |
I got a message that i have 21 days to evaluate danali package 12, but I think i'm still on CQG how can i switch from CQG to Denali?
Date Time Of Last Edit: 2022-05-13 16:31:15
[2022-05-13 16:50:47] |
First of all, the reason for the message is that you had selected the option to evaluate the highest available package (which is Package 12 right now). This gives you 30 days of Package 12 trial time. If you want to change to the Denali Exchange Data Feed, then you need to go through the Setup Instructions for the Denali Exchange Data Feed at the following link for the CME Group data: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* If you need data for EUREX, CFE, or NASDAQ TotalView, then follow these Setup Instructions: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
