Date/Time: Thu, 24 Sep 2026 09:44:29 +0000
Marking value area and poc in the TPO Chart
View Count: 1379
| [2022-05-12 18:32:34] |
| User576648 - Posts: 26 |
MY TPO Chart got a custom intraday session period, The ON and RTH. The TPO uses a volume profile to extract the value area high and low and POC on a 30 min TPO but that doesn't affect the levels since it's based on volume. I would like to mark the ON value area high and low and POC to be shown on the far right side. I use volume value area lines but they are based on ETH. is there a way around this?
| [2022-05-12 20:21:29] |
| John - SC Support - Posts: 47994 |
You would have to have another chart that has the ON session with the Volume Value Area Lines on it and then use the Study/Price Overlay to put the information on the main chart. It sounds like you would want to use a Draw Style of Subgraph Name and Value Labels Only and then turn on the Name or Value Labels (depending on what you want to see). Refer to the following for the Volume Value Area Lines study: Volume Value Area Lines Refer to the following for the Study/Price Overlay study: Study/Price Overlay Study And refer to the following for the Subgraph Name and Value Labels Only draw style: Chart Studies: Subgraph Name and Value Labels Only (ACSIL: DRAWSTYLE_SUBGRAPH_NAME_AND_VALUE_LABELS_ONLY) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
