Date/Time: Wed, 14 Oct 2026 23:07:58 +0000
Change text color for RV
View Count: 821
| [2022-05-11 17:13:42] |
| User525965 - Posts: 180 |
how do I change the color of this? see attached. thanks
| [2022-05-11 17:51:38] |
| John - SC Support - Posts: 48209 |
That entire line across the top is the Chart Header. The color of the header is defined by the Chart Text setting. Refer to the information here: Graphics Settings: Chart Text If you are wanting to set that item to be Reversed Colors (hence it appears highlighted), then you would do that through Global Settings >> Customize Chart Header - Standard. Refer to the information here: Working With Charts: Region Data Line / Chart Header For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-05-11 17:51:53
