Date/Time: Sat, 04 May 2024 19:17:39 +0000
Hong Kong Futures Exchange
View Count: 721
[2022-05-05 06:35:11] |
User296389 - Posts: 31 |
Hi, Is the Hang Seng Index ( Cash Market ) real time data included in the Hong Kong Futures Exchange 16 USD/mth package? Thank you. Best Regards, Darren |
[2022-05-05 07:34:36] |
No it is not.
[2022-05-05 14:06:45] |
Hi, Can i use the data feed from Interactive Brokers and integrate with sierra chart, for the Hang Seng Index ( Cash market ) data? Thanks. |
[2022-05-05 14:24:59] |
John - SC Support - Posts: 31362 |
Yes.
[2022-07-04 00:29:49] |
User379468 - Posts: 508 |
How can one integrate that Hang Seng/other international indices data from IB into SC, and what's the symbol/where is it listed in SC? I don't see Hang Seng under IB Indices.
[2022-07-04 09:17:36] |
You need to manually enter the symbols according to the Interactive Brokers symbol formats: Interactive Brokers Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-24 06:12:33] |
User546152 - Posts: 2 |
Hello, May I ask how do I subscribe to real time Hang Seng Futures Data? I am on package 10 on Denali Feed but the exchanges listed do not have Hang Seng HKEX? What do I do, thanks |
[2023-05-24 08:58:04] |
Sierra_Chart Engineering - Posts: 14223 |
Sierra Chart does not offer this data any longer. You can check with Interactive Brokers: https://www.sierrachart.com/index.php?page=doc/Contents.php#SupportedDataAndTradingServices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-24 08:58:09
[2023-05-24 09:46:37] |
Thank you for your reply, can I use TradingView to connect? I have subscribed HKEX data with tradingview |
[2023-05-24 11:25:25] |
No that is not supported.
[2023-07-12 17:11:44] |
Sami2 - Posts: 11 |
Hello, If we have CQG Data, are we able to see HKG33 real time data? Thank you. |
[2023-07-12 17:32:46] |
Yes, you can use CQG to get the real-time HKEX data into Sierra Chart.
