Date/Time: Mon, 06 May 2024 17:11:39 +0000
delayed data
View Count: 324
[2022-05-03 16:14:25] |
jakeybleez - Posts: 49 |
hello, im on my laptop trading and i noticed it is delayed and says delayed up top. im aware you're only allowed one device at a time, but i've never had a problem as long as i was only logged in one device at a time thanks Jake |
[2022-05-03 16:39:54] |
John - SC Support - Posts: 31401 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
