Date/Time: Fri, 03 May 2024 09:52:01 +0000
Which Service should I activate?
View Count: 344
[2022-04-28 15:01:44] |
User798274 - Posts: 14 |
Hi I'd like to use Sierra Chart as a Research Software which means that I won't need real time data for CME. Do I have to book the Denali Feed for that?
[2022-04-28 16:49:36] |
John - SC Support - Posts: 31334 |
If you can use the Delayed Streaming Data, then you do not need to sign up for any real-time data. You would just need an active Sierra Chart package. Refer to the information for the delayed data here: Delayed Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-28 17:34:18] |
Does that mean subscribing to 3 or 5 would be enough for me?
[2022-04-28 20:28:18] |
Yes, that is correct. Either of those will give you access to the Delayed Streaming data for the CME Group, EUREX, CFE, and NASDAQ TotalView. Refer to the information at the following link for the differences in the packages: Description of Service Packages and Pricing: Packages For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
