Date/Time: Mon, 06 May 2024 22:46:45 +0000
Delayed Equity Data
View Count: 500
[2022-04-07 17:31:51] |
Sargon Petros - Posts: 52 |
Hi, I have several custom symbols that have recently stopped working correctly and are showing delayed data by approx 15 mins. I've activated Nasdaq on my account, but I still have the same issue. I noticed you guys have changed from Barchart, is there something I need to do for my custom symbols? I'm simply doing things like ADBE+NFLX+PYPL for example. |
[2022-04-07 18:21:47] |
John - SC Support - Posts: 31412 |
Since you are now using the NASDAQ TotalView exchange, you would need to add the suffix -NQTV to each symbol. Without that suffix, you would be getting the delayed data from BarChart. With the suffix, you will get the real-time NASDAQ TotalView data. For example, for your Custom Calculated Symbol, you would need to have {ABDE-NQTV} + {NFLX-NQTV} + {PYPL-NQTV}. Keep in mind you need the -NQTV for all symbols, not just the Custom Calculated ones. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-07 23:09:14] |
Great! Thank you so much.
[2022-04-08 11:09:42] |
Can you see anything wrong with this? {ADBE-NQTV}+{NFLX-NQTV}+{PYPL-NQTV}+{CMCSA-NQTV}+{CSCO-NQTV}+{AVGO-NQTV}+{COST-NQTV}+{PEP-NQTV}+{INTC-NQTV}+{QCOM-NQTV}+{AMD-NQTV}+{TXN-NQTV}+{INTU-NQTV} I've another list of nasdaq constituents that work fine, but this one doesn't. I don't see anything obvious in my logs. |
[2022-04-20 15:04:56] |
That formula does look fine to us. Refer to the information here: Custom Calculated Symbols: Meaning of FSC and FSE Displayed After the Symbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
