Date/Time: Fri, 03 May 2024 21:27:34 +0000
Chart Settings window showing differently than before
View Count: 742
[2022-03-28 13:29:18] |
User277893 - Posts: 5 |
Hi Sierra, I used to left-click on a chart, then click on Chart Settings to get to a window with tabs that helped me change the settings of my chart. I opened Sierra yesterday after a few days of being away from the screens, and when I follow the procedure described above, I then get a very different window with sliding menus. How can I turn Sierra to continue showing the Chart Settings as before? Thanks. Please see image with current result. |
Screenshot 2022-03-28 062740.jpg / V - Attached On 2022-03-28 13:27:58 UTC - Size: 183.39 KB - 116 views |
[2022-03-28 16:39:42] |
John - SC Support - Posts: 31361 |
This is the new Chart Settings window. This is the new style of windows that we are moving all of Sierra Chart to. Refer to the following for information on how to work with these windows: Settings Windows Interface For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-01 04:38:29] |
User83524 - Posts: 27 |
Obviously, the newer format provides more customization options, but the older one was much more user friendly and better visibility. It's a toss-up to which one is better, but I prefer the older one. Not an improvement for me.
