Date/Time: Wed, 14 Oct 2026 16:16:31 +0000
Historical Data with Amp
View Count: 878
| [2022-03-04 15:19:17] |
| User874834 - Posts: 3 |
Hi I don't get any historical data unless I enter my amp credentials
| [2022-03-04 17:59:11] |
| John - SC Support - Posts: 48203 |
Our servers are showing that you are using Rithmic for your data. Refer to the information here: Rithmic Trading Platform Service: Rithmic Support Policy For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-03-04 19:28:59] |
When I use the Denali Feed for market data, can i trade through my AMP account with rithmic ?
Date Time Of Last Edit: 2022-03-04 19:59:27
| [2022-03-04 21:28:55] |
Yes, Sierra Chart is specifically setup to allow this. Refer to the information here: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services Follow the instructions at the following link to setup the Denali Exchange Data Feed for the CME Group: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* If you require data for EUREX, CFE, or NASDAQ, then follow these instructions: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
