Date/Time: Mon, 19 Oct 2026 03:00:56 +0000
Options trading with SC all Data Services
View Count: 3236
[2022-03-04 01:19:39]
User250581 - Posts: 22
I wanna trade the MES options so I set my data services to "SC all data services" and after finding the MES futures contract and selected "find options" i couldn easily get the options data and copy them straight from the clipboard to the spreadsheet and then to the Dom. The problem begins when start to hit the buy button as the trading mode suddenly switches from my trading account to the [SIM mode} mode. I tried to switch the data services and connect to interactive brokers instead but now i cant get the options data period. I have denali package 11 with nasdaq top of the book activated plus all CME data activated. Am i missing any thing?
PS- I enabled the "allow support for SC data feed" from the Data services menu and im receiving live data but the problem is whenever i try to trade the ES or MES options it constantly switches the live acccount to the SIM trading mode even when i disable the SIM trading mode.
[2022-03-04 23:19:55]
We do not understand why you would have to do this. You should not have to do anything like this:
You simply select the options symbol in the list of available symbols, and then press the Open Trading DOM button on the Find Symbol window.
You need to follow the instructions here:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
To do what you want, follow through the instructions here:
Denali Exchange Data Feed: Denali Futures Options Data with Other Trading Services
[2022-03-05 02:49:28]
when i connect sierra with interactive broker i cant get options, the "get options" button doesnt even appear like it does when im connected to SC all services.
Private File
Private File
[2022-03-05 02:54:28]
but when im connected to SC all services i can see the "get options" button
imageCapture3.PNG / V - Attached On 2022-03-05 02:54:09 UTC - Size: 21.33 KB - 397 views
imageCapture4.PNG / V - Attached On 2022-03-05 02:54:16 UTC - Size: 39.65 KB - 414 views
[2022-03-07 15:34:51]
John - SC Support - Posts: 48239
When you are connected to Interactive Brokers you should have entries in the Find Symbols page for Futures Options. You need to open the section you want and select the appropriate instrument and then select the button for Get Options.
What you show in your images is that you are selecting the section for a Spread, not an Option.
[2022-03-07 22:56:10]
Sierra_Chart Engineering - Posts: 25213
We added a screenshot at Step 4 here:
