Date/Time: Sat, 31 Oct 2026 20:12:21 +0000
Not receiving Real-Time data
View Count: 849
[2022-03-02 02:56:51]
jonntran - Posts: 3
I am having issues receiving real-time data. I checked global settings -> data/trade service settings, and it is currently set with:
Teton CME Order Routing and Advantage/Stage5.
Help is appreciated.
Thank you,
Software version: 2362 64-bit | 2022-03-02 02:40:57.319
Primary Thread ID: 596 | 2022-03-02 02:40:57.319
Usage end date: 2022-06-02 | 2022-03-02 02:40:57.319
Enabled for: Advanced Features 2. | 2022-03-02 02:40:57.319
Enabled for: Sierra Chart Historical Data Service. | 2022-03-02 02:40:57.319
Enabled for: Denali Real-Time Exchange Data Feed. | 2022-03-02 02:40:57.319
Enabled for: Delayed Denali Exchange Data Feed. | 2022-03-02 02:40:57.319
Enabled for exchange2: fairx_exchange.data | 2022-03-02 02:40:57.319
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-03-02 02:40:57.319
Current selected Data/Trading service: Teton CME Order Routing | 2022-03-02 02:40:57.319
Custom symbol settings values: enabled | 2022-03-02 02:40:57.319
Chart Update Interval: 500 | 2022-03-02 02:40:57.319
Intraday Data Storage Time Unit: 0 | 2022-03-02 02:40:57.319
Time Zone: +00:00:00 (UTC+00) | 2022-03-02 02:40:57.319
2022-03-02 02:40:57 Local computer time in UTC | 2022-03-02 02:40:57.319
2022-03-02 02:40:57 Local computer time in SC Time Zone | 2022-03-02 02:40:57.319
2022-03-02 02:28:26 Server time in UTC | 2022-03-02 02:40:57.319
Local computer UTC time and Server UTC time difference: 0 seconds. | 2022-03-02 02:40:57.319
Program path: C:\SierraChart\ | 2022-03-02 02:40:57.319
Data Files path: C:\SierraChart\Data\ | 2022-03-02 02:40:57.319
OS Version Number: 6.1 | 2022-03-02 02:40:57.319
Locale Setting: C | 2022-03-02 02:40:57.319
DLLs: UserContributedStudies_64.dll | 2022-03-02 02:40:57.320
Allowed protected custom studies: | 2022-03-02 02:40:57.320
File >> Disconnect selected. | 2022-03-02 02:41:05.084
Teton CME Order Routing | Waiting for socket receive thread to end | 2022-03-02 02:41:05.084
DTC Client socket (1) | CloseSocket call. | 2022-03-02 02:41:05.085
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-03-02 02:41:05.085
| Waiting for socket receive thread to end | 2022-03-02 02:41:05.085
DTC Client socket (2) | CloseSocket call. | 2022-03-02 02:41:05.086
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-03-02 02:41:05.086
| Disconnected from the server. | 2022-03-02 02:41:05.086
Teton CME Order Routing | Disconnected. | 2022-03-02 02:41:05.086
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-03-02 02:41:05.121
DTC Client socket (1) | Closed. | 2022-03-02 02:41:05.121
Teton CME Order Routing | Connecting to the server futurestrading2.sierracharts.com. Port 11093 | 2022-03-02 02:41:15.534
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-03-02 02:41:15.562
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-03-02 02:41:15.563
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2022-03-02 02:41:15.563
Teton CME Order Routing | Network connection to server complete. | 2022-03-02 02:41:15.836
Teton CME Order Routing | Starting socket receive thread. | 2022-03-02 02:41:15.836
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-03-02 02:41:15.836
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-03-02 02:41:15.951
Teton CME Order Routing | Sending logon request message. | 2022-03-02 02:41:15.951
Teton CME Order Routing | Received logon response. | 2022-03-02 02:41:16.458
Teton CME Order Routing | Server Name: SC DTC Server. Build=41200. | 2022-03-02 02:41:16.458
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-03-02 02:41:16.458
Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-03-02 02:41:16.458
Teton CME Order Routing | Trading is supported. | 2022-03-02 02:41:16.458
Teton CME Order Routing | Order cancel and replace is supported. | 2022-03-02 02:41:16.458
Teton CME Order Routing | OCO Orders supported. | 2022-03-02 02:41:16.458
Teton CME Order Routing | Bracket Orders supported. | 2022-03-02 02:41:16.458
Teton CME Order Routing | Connected to server complete. | 2022-03-02 02:41:16.458
Triggering next historical data download in queue. | 2022-03-02 02:41:16.459
Updated verified funded futures trading account ending date to: 2022-04-01 02:41:16 | 2022-03-02 02:41:16.459
No download requests in the queue to start downloads for. | 2022-03-02 02:41:16.459
No download requests in the queue to start downloads for. | 2022-03-02 02:41:16.460
Updated verified funded futures trading account ending date to: 2022-04-01 02:41:16 | 2022-03-02 02:41:16.496
https://www.sierrachart.com/image.php?Image=164618955520.png
[2022-03-02 17:52:05]
You have not completed the data setup for the Denali Exchange Data Feed. In particular, you have not activated the exchanges for which you want the real-time data.
For the CME Group, you would activate the exchanges at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges
For the NASDAQ TotalView, you would activate the exchange at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeedNASDAQ#Exchanges
If you need data for EUREX or CFE, then you would need to follow through the Setup Instructions for those exchanges at the following link:
Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges*
