Date/Time: Thu, 16 May 2024 11:35:10 +0000
Is there any trade copier that can copy both parent and child orders? (discussion)
View Count: 1508
[2022-02-28 21:06:56] |
SabikiSensei - Posts: 74 |
Would like to purchase it. There doesn't seem to be any services that I can find that offer this.. which is ridiculous because Ninjatrader has at least 2. The order allocation is almost perfect.. if only it could modify child orders to the slave account. There's a lot of people that want this and we can't wait till this feature is implemented. |
[2022-02-28 22:16:12] |
. if only it could modify child orders to the slave account. Will try to have this feature done in about two weeks. And then this feature here will have what you need:Order Allocation to Trade Accounts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-25 01:45:47] |
Am I understanding correctly that once I enter a trade, if I modify the TP/SL it will also reflect in the slave account? I tried it with sim 1 and sim 2 accounts today and it worked perfectly with the secondary account also exiting at a moved TP/SL level. "One exception to this is when the parent order fills, the Attached Orders for the original order will not cause the Attached Orders for the identical orders allocated to other accounts, to be modified in the same way since that will happen automatically with their own parent order." This part confused me because it reads like modified child orders do not reflect in the slave account. Date Time Of Last Edit: 2022-03-25 01:46:25
[2022-03-28 21:25:45] |
Sierra_Chart Engineering - Posts: 14362 |
First, it is important that you run the latest version of Sierra Chart for this functionality. Update instructions: Software Download: Fast Update Yes this is correct: Am I understanding correctly that once I enter a trade, if I modify the TP/SL it will also reflect in the slave account?
Disregard the section you quoted in your post. You are misunderstanding it. The functionality will work as you expect. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-28 21:26:17
[2023-08-24 17:15:37] |
Galmik - Posts: 28 |
Hi Do we have any news on the trade copier? I have many fellow traders that use ninja trader for this and i am a little bit jealous of them. I use order allocation now but have a rythmic account and a teton account that i want to connect and trade Thank you |
[2023-08-24 21:06:02] |
John - SC Support - Posts: 31666 |
We do not have the functionality to copy trades between different brokers. Nor is this going to come any time soon, if at all.
[2023-09-05 17:53:08] |
@sstfrederik - Posts: 403 |
shameless plug. this is an option if interested: https://www.simplesystemtrading.com/local-trade-copier/ |
