Date/Time: Mon, 06 May 2024 10:49:41 +0000
Delayed Futures Data
View Count: 388
[2022-02-24 15:20:35] |
shanks001 - Posts: 1 |
AGAIN with the delayed data. why does this KEEP HAPPENING
[2022-02-24 16:05:56] |
John - SC Support - Posts: 31379 |
Everything on your account looks good. If you are still having an issue then we need to see your Message Log by following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
