Date/Time: Mon, 06 Feb 2023 06:32:57 +0000
does SC cover any products on the Brazilian exchanges
View Count: 402
[2022-02-22 09:31:23] |
User849502 - Posts: 202 |
Hi, The Brazilian short term interest rates a huge and I was wondering if SC covers them. I know TT does. They are the Di1. I don't see any thing Brazil wise in the symbol look up. thank you very much for your time |
[2022-02-22 17:32:40] |
This would only be supported through CQG: CQG Trading Platform Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-27 18:23:32] |
User17018123 - Posts: 5 |
Hi All, 1)does Sierra support trading and data for B3 using CQG? 2)Some questions apply other exchanges available with CQG but not with TETON. The TT order routing is still available? Thanks |
[2022-09-27 21:21:26] |
John - SC Support - Posts: 21946 |
1. As long as you can get the data from CQG and you are using them for the order routing, then you can use Sierra Chart to Trade and Chart B3. We do not have data for the B3. 2. Same answer as above. As long as you are able to get the data from CQG and bring it into Sierra Chart, then you can use those charts to place orders with CQG. The Sierra Chart Order Routing using TT is no longer available. We only have our Teton Order Routing service, which is a direct connection to the exchange. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-28 07:07:14] |
Hi John, thanks for this. Are you saying that if I got CQG data service I could then make charts for Brazil? But I cannot make charts for Brazil using my Teton or SC All Services - is that right? Thanks for keeping me in the loop. Karen |
[2022-09-28 14:26:59] |
Yes, what you state is exactly what we are saying.
[2022-10-07 17:48:03] |
OK. 1)Does DTC server work to get data from SC connected to CQG feed for not CME exchanges ? 2)Is trading supported as well via DTC using CQG routing (same as above but for trading)? Thanks Date Time Of Last Edit: 2022-10-07 17:48:39
[2022-10-07 20:42:39] |
1/2. The DTC protocol is not used for data or trading from CQG. There is a specific interface that was developed for CQG.
[2022-10-08 16:09:04] |
What is this specific interface?You mean standard ACSIL trading functionalities ?
[2022-10-08 17:19:09] |
Sierra_Chart Engineering - Posts: 6483 |
We think there was a misunderstanding regarding the answer given at post #8. 1)Does DTC server work to get data from SC connected to CQG feed for not CME exchanges ? 2)Is trading supported as well via DTC using CQG routing (same as above but for trading)? 2. Yes this is supported. There are no restrictions with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-08 17:19:23
