Date/Time: Tue, 30 Apr 2024 07:44:03 +0000
Display delayed data instead of real-time
View Count: 469
[2022-02-01 07:19:13] |
Yuri_T - Posts: 14 |
I have Denali DF and CME real-time data. I want to try out Euro-Bund and look at it simultaneously with 6E. But for now I do not want to pay for EUREX real-time data. Can I make my 6E chart show me delayed data to synchronize it with Euro-Bund chart without cancelling CME exchange subscription? Or is it only Chart Replay that I can use to synchronize 6E chart with delayed Euro-Bund data?
[2022-02-01 13:06:40] |
You can make all of the data delayed by setting this option to No: Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds And reconnecting to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-01 13:07:20
[2022-02-01 14:15:10] |
I know I should just press "Thank you", but I want to write it. Thank you, guys! You are awesome!
