Date/Time: Fri, 09 Oct 2026 08:13:37 +0000
Feature Requests - Delta Profiles, Integration of Hull, Adaptive, Least Square Moving Averages i
View Count: 1645
| [2014-04-10 20:12:26] |
| cmet - Posts: 743 |
Delta Profiles - These are basically identical to the Volume by Price profiles but they would use Delta by Price. Or, in other words, Ask/Bid Volume Difference by Price. Very valuable in showing at which prices buyers/sellers were more/most aggressive. Moving Average Integration - Almost all studies only offer simple, exponential, linear reg, weighted, smoothed. All of these averages have considerable lag. Hull and Least Square are much more responsive when used in indicators. Adaptive averages are very good at filtering noise. Would be nice to be able to calculate based on these. |
| [2014-04-11 04:51:20] |
This can be done with the Numbers Bars study: https://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php Moving Average Integration - Almost all studies only offer simple, exponential, linear reg, weighted, smoothed. All of these averages have considerable lag. Hull and Least Square are much more responsive when used in indicators. Adaptive averages are very good at filtering noise. Would be nice to be able to calculate based on these. https://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#MovingAverageType Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-04-11 04:51:59
| [2014-04-11 12:40:09] |
| cmet - Posts: 743 |
Thank you. With regards to Delta Profiles, I am more interested in plotting one big profile for the day and having it pinned to the right edge of the chart. Is this possible? Having it on every intraday bar is too granular for me. |
| [2014-04-11 16:12:27] |
Not exactly. However , the Volume by Price study can be set to display the difference between Ask Volume and Bid Volume of each volume bar. Each volume bar will represent the total volume at the price level.
