Date/Time: Mon, 06 May 2024 03:37:10 +0000
IB-CME real time symbol issues
View Count: 2311
[2014-04-09 13:16:11] |
steve_s - Posts: 11 |
Hi, I requested the mini grain futures (XC, XW, XK) be added a while back to the CME real time feed for Interactive Brokers(IB). I recently tried to go live with them and it appears they aren't mapped correctly. If I submit a limit order it just sits there forever saying order sent and IB shows no order pending. I have attached a screen shot of the API log and a screenshot of the IB symbol info as well. Also, I am not receiving live data for the Swiss Franc futures symbol (CHF). I get data when i do a delete and download but it never updates in real time. And finally the micro canadian dollar future (MCD) says it downloads data successfully but my screen is blank i.e. i see no bars- this symbol was working for me and I've tried to get the data in multiple instances but have had no luck. Thanks for any help you can provide. Steve. |
ib mini corn futures api log.PNG / V - Attached On 2014-04-09 13:12:43 UTC - Size: 11.39 KB - 360 views mini corn futures ib info.PNG / V - Attached On 2014-04-09 13:12:58 UTC - Size: 15.71 KB - 434 views |
[2014-04-09 17:55:23] |
For the CHF symbol do you see a [M] indicator after the symbol at the top of the chart? In the case of MCD, no one is trading this market at all. That is why the chart is blank. For XC we have added 1000 to the symbol to specify the multiplier. Restart Sierra Chart to get the updated symbol settings . Open a new chart for that symbol using the symbol that contains 1000 and give it a try. If there is still a problem, we do not know what else can be done. You will need to ask Interactive Brokers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-09 19:37:41] |
Yes, there is an [M] after the CHF symbol. As far as MCD of course people trade it, it's listed on my IB screen and I can enter an order through trader workstation just fine. Yes, it's a micro, yes it trades miniscule volume, but miniscule volume is not the problem I'm asking help with. I'm asking to be able to get the data into sierra and execute orders through sierra using this symbol which is listed on the CME globex system. As I said, it was working before. As for XC, it still doesn't work. Perhaps it needs to be mapped with YC as that is what IB considers the underlying even though CME uses XC. Thanks again for any help you can provide. Steve. |
[2014-04-10 01:22:02] |
Yes, there is an [M] after the CHF symbol. Provide the Message Log, by following these instructions:https://www.sierrachart.com/index.php?l=PostingInformation.php#log We see no data for the symbol identified as M6C from the CME. There are is absolutely no trading going on in that market for the last several months. With the Sierra Chart data feed MCD is mapped to M6C. Here are the symbol formats you can use in Sierra Chart for Interactive Brokers: https://www.sierrachart.com/index.php?l=doc/IBSymbols.html You can use whatever symbols you want and you are free to do whatever testing you need to for these other markets. We recommend a trial and error procedure and consulting with IB technical support. When you figure out the correct symbol you can let us know and we can update the Symbol Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-04-10 01:22:22
[2014-05-15 13:22:38] |
Hi, sorry for the delay. I'm still not getting real time updates for CHF-201406-GLOBEX. There is an [M] and i get historical data but that's it. Thanks. Software version: 1137 | 2014-05-15 13:16:26 Usage end date: 2014-06-26 | 2014-05-15 13:16:26 Enabled for: Advanced Features. | 2014-05-15 13:16:26 Enabled for: Sierra Chart Historical Data Service. | 2014-05-15 13:16:26 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2014-05-15 13:16:26 Enabled for: CME, CBOT, NYMEX, COMEX exchanges. | 2014-05-15 13:16:26 Received 2 data feed usernames. | 2014-05-15 13:16:26 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-05-15 13:16:26 Active service: Interactive Brokers | 2014-05-15 13:16:26 Time Zone: +00:00:00 (UTC+00) | 2014-05-15 13:16:26 2014-05-15 09:16:26 Local computer clock time | 2014-05-15 13:16:26 2014-05-15 13:16:26 GMT time | 2014-05-15 13:16:26 2014-05-15 13:16:26 Time zone adjusted time | 2014-05-15 13:16:26 Time difference to server time: 11 seconds. | 2014-05-15 13:16:26 Program path: C:\Matrix Live-SIM\ | 2014-05-15 13:16:26 Data Files path: C:\Matrix Live-SIM\Data\ | 2014-05-15 13:16:26 OS Version Number: 6.1 | 2014-05-15 13:16:26 Checking for new symbol settings for ib | 2014-05-15 13:16:26 Symbol settings are up-to-date for ib | 2014-05-15 13:16:26 Interactive Brokers: Connecting to 127.0.0.1:7497 | 2014-05-15 13:16:31 The network socket is connected. | 2014-05-15 13:16:31 Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-05-15 13:16:31 TWS server version: 70 | 2014-05-15 13:16:31 IB: Connected. Waiting for account information. | 2014-05-15 13:16:31 IB Account information received. | 2014-05-15 13:16:31 Connected to IB Demo or Simulated account. | 2014-05-15 13:16:31 Interactive Brokers: Requesting Trade Positions for account: DU137835 | 2014-05-15 13:16:31 Next valid order ID: 1 | 2014-05-15 13:16:31 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2014-05-15 13:16:31 Message from IB: Market data farm connection is OK:eurofarm. IB Error Code: 2104. Request ID: -1. | 2014-05-15 13:16:31 Message from IB: Market data farm connection is OK:usfuture.us. IB Error Code: 2104. Request ID: -1. | 2014-05-15 13:16:31 Message from IB: Market data farm connection is OK:hkfarm. IB Error Code: 2104. Request ID: -1. | 2014-05-15 13:16:31 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2014-05-15 13:16:31 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2014-05-15 13:16:31 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2014-05-15 13:16:31 Message from IB: HMDS data farm connection is OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2014-05-15 13:16:31 Message from IB: HMDS data farm connection is OK:hkhmds. IB Error Code: 2106. Request ID: -1. | 2014-05-15 13:16:31 Message from IB: HMDS data farm connection is inactive but should be available upon demand.ushmds. IB Error Code: 2107. Request ID: -1. | 2014-05-15 13:16:31 Next valid order ID: 1 | 2014-05-15 13:16:31 IB Account information received. | 2014-05-15 13:16:31 Connected to IB Demo or Simulated account. | 2014-05-15 13:16:31 Interactive Brokers: Received Trade Positions download end message for account DU137835 | 2014-05-15 13:16:31 Starting remote Sierra Chart instance "C:\SierraChart\SierraChart.exe". | 2014-05-15 13:16:36 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-03-11 14:00:00. Next Bar Date Time: 2014-03-11 13:00:00. Filename: C:\SierraChart\Data\DX-201403-NYBOT.scid | 2014-05-15 13:16:36 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-03-12 04:00:00. Next Bar Date Time: 2014-03-12 03:30:00. Filename: C:\SierraChart\Data\DX-201403-NYBOT.scid | 2014-05-15 13:16:36 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-03-13 03:30:00. Next Bar Date Time: 2014-03-13 02:30:00. Filename: C:\SierraChart\Data\DX-201403-NYBOT.scid | 2014-05-15 13:16:36 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-03-13 04:00:00. Next Bar Date Time: 2014-03-13 03:00:00. Filename: C:\SierraChart\Data\DX-201403-NYBOT.scid | 2014-05-15 13:16:36 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-03-13 16:00:00. Next Bar Date Time: 2014-03-13 15:00:00. Filename: C:\SierraChart\Data\DX-201403-NYBOT.scid | 2014-05-15 13:16:36 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-03-14 04:30:00. Next Bar Date Time: 2014-03-14 03:30:00. Filename: C:\SierraChart\Data\DX-201403-NYBOT.scid | 2014-05-15 13:16:36 Mapping EUR-201406-GLOBEX to 6EM4. Service code: cme | 2014-05-15 13:16:44 SC Exchange Data - Starting real-time market data updates for: 6EM4 | 2014-05-15 13:16:44 Using username 0 | 2014-05-15 13:16:44 SC Exchange Data: Connecting to the server scdf1.sierracharts.com. Port 443 | 2014-05-15 13:16:44 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-05-15 13:16:45 HD Request # 2 - Downloading Intraday chart data for EUR-201406-GLOBEX to the file EUR-201406-GLOBEX.scid. Service: cme | 2014-05-15 13:16:45 HD Request # 2 - Download start Date-Time: 2014-05-15 13:16:22.0 | 2014-05-15 13:16:45 HD Request # 2 - Using server: scdf1.sierracharts.com port 10149 | 2014-05-15 13:16:45 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-05-15 13:16:45 The network socket is connected. | 2014-05-15 13:16:45 HD Request # 2 - Sending historical data logon request message. | 2014-05-15 13:16:45 The network socket is connected. | 2014-05-15 13:16:45 SC Exchange Data: Connected to server. | 2014-05-15 13:16:45 SC Exchange Data: Sending logon request message. | 2014-05-15 13:16:45 Mapping E7-201406-GLOBEX-USD to E7M4. Service code: cme | 2014-05-15 13:16:45 SC Exchange Data - Starting real-time market data updates for: E7M4 | 2014-05-15 13:16:45 Mapping M6E-201406-GLOBEX to M6EM4. Service code: cme | 2014-05-15 13:16:45 SC Exchange Data - Starting real-time market data updates for: M6EM4 | 2014-05-15 13:16:45 Mapping JPY-201406-GLOBEX to 6JM4. Service code: cme | 2014-05-15 13:16:45 SC Exchange Data - Starting real-time market data updates for: 6JM4 | 2014-05-15 13:16:45 Mapping J7-201406-GLOBEX-USD to J7M4. Service code: cme | 2014-05-15 13:16:45 SC Exchange Data - Starting real-time market data updates for: J7M4 | 2014-05-15 13:16:45 Interactive Brokers - Starting real-time market data updates for: MJY-201406-GLOBEX | 2014-05-15 13:16:45 Subscribing to real-time True Data for symbol: MJY SecType: FUT Exchange: GLOBEX Currency: | 2014-05-15 13:16:45 Subscribing to symbol: MJY SecType: FUT Expiry: 201406 Exchange: GLOBEX Currency: Multiplier: | 2014-05-15 13:16:45 Mapping GBP-201406-GLOBEX to 6BM4. Service code: cme | 2014-05-15 13:16:45 SC Exchange Data - Starting real-time market data updates for: 6BM4 | 2014-05-15 13:16:45 Mapping M6B-201406-GLOBEX-USD to M6BM4. Service code: cme | 2014-05-15 13:16:45 SC Exchange Data - Starting real-time market data updates for: M6BM4 | 2014-05-15 13:16:45 Mapping AUD-201406-GLOBEX to 6AM4. Service code: cme | 2014-05-15 13:16:46 SC Exchange Data - Starting real-time market data updates for: 6AM4 | 2014-05-15 13:16:46 Mapping M6A-201406-GLOBEX-USD to M6AM4. Service code: cme | 2014-05-15 13:16:46 SC Exchange Data - Starting real-time market data updates for: M6AM4 | 2014-05-15 13:16:46 HD Request # 2 - Requesting Intraday data. Start Date-Time: 2014-05-15 13:16:22. Record interval: 1 . Symbol: 6EM4 | 2014-05-15 13:16:46 HD Request # 2 - Decompressing data. | 2014-05-15 13:16:46 HD Request # 2 - Receiving Intraday data for EUR-201406-GLOBEX starting at 2014-05-15 13:16:22 | 2014-05-15 13:16:46 HD Request # 2 - Timestamp of first Intraday data file record written: 2014-05-15 13:16:22 | 2014-05-15 13:16:46 Socket has been shutdown and closed. | 2014-05-15 13:16:46 The network socket for historical data has been closed. | 2014-05-15 13:16:46 SC Exchange Data Server Info - Server Name: . Server Version: . Provider Name: . | 2014-05-15 13:16:46 SC Exchange Data - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-05-15 13:16:46 SC Exchange Data - Successfully connected. | 2014-05-15 13:16:46 SC Exchange Data - Restarting real-time data updates for symbol: AUD-201406-GLOBEX -> 6AM4 | 2014-05-15 13:16:46 SC Exchange Data - Restarting real-time data updates for symbol: E7-201406-GLOBEX-USD -> E7M4 | 2014-05-15 13:16:46 SC Exchange Data - Restarting real-time data updates for symbol: EUR-201406-GLOBEX -> 6EM4 | 2014-05-15 13:16:46 SC Exchange Data - Restarting real-time data updates for symbol: GBP-201406-GLOBEX -> 6BM4 | 2014-05-15 13:16:46 SC Exchange Data - Restarting real-time data updates for symbol: J7-201406-GLOBEX-USD -> J7M4 | 2014-05-15 13:16:46 SC Exchange Data - Restarting real-time data updates for symbol: JPY-201406-GLOBEX -> 6JM4 | 2014-05-15 13:16:46 SC Exchange Data - Restarting real-time data updates for symbol: M6A-201406-GLOBEX-USD -> M6AM4 | 2014-05-15 13:16:46 SC Exchange Data - Restarting real-time data updates for symbol: M6B-201406-GLOBEX-USD -> M6BM4 | 2014-05-15 13:16:46 SC Exchange Data - Restarting real-time data updates for symbol: M6E-201406-GLOBEX -> M6EM4 | 2014-05-15 13:16:46 HD Request # 2 - Received 7 records from 2014-05-15 13:16:22 to 2014-05-15 13:16:52 (30.0 seconds) and wrote 7 records for EUR-201406-GLOBEX | 2014-05-15 13:16:46 HD Request # 2 - Intraday download COMPLETE for EUR-201406-GLOBEX. Completion time: 0s | 2014-05-15 13:16:46 Real-time Intraday chart data file updates started for EUR-201406-GLOBEX | 2014-05-15 13:16:46 HD Request # 3 - Downloading Intraday chart data for E7-201406-GLOBEX-USD to the file E7-201406-GLOBEX-USD.scid. Service: cme | 2014-05-15 13:16:46 HD Request # 3 - Download start Date-Time: 2014-05-15 13:16:07.0 | 2014-05-15 13:16:46 HD Request # 3 - Using server: scdf2.sierracharts.com port 10149 | 2014-05-15 13:16:46 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-05-15 13:16:46 Mapping CAD-201406-GLOBEX to 6CM4. Service code: cme | 2014-05-15 13:16:46 SC Exchange Data - Starting real-time market data updates for: 6CM4 | 2014-05-15 13:16:46 The network socket is connected. | 2014-05-15 13:16:46 HD Request # 3 - Sending historical data logon request message. | 2014-05-15 13:16:46 Interactive Brokers - Starting real-time market data updates for: MCD-201406-GLOBEX | 2014-05-15 13:16:46 Subscribing to real-time True Data for symbol: MCD SecType: FUT Exchange: GLOBEX Currency: | 2014-05-15 13:16:46 Subscribing to symbol: MCD SecType: FUT Expiry: 201406 Exchange: GLOBEX Currency: Multiplier: | 2014-05-15 13:16:46 Mapping CHF-201406-GLOBEX to 6SM4. Service code: cme | 2014-05-15 13:16:46 SC Exchange Data - Starting real-time market data updates for: 6SM4 | 2014-05-15 13:16:46 Mapping MSF-201406-GLOBEX-USD to 6SM4. Service code: cme | 2014-05-15 13:16:46 SC Exchange Data - Starting real-time market data updates for: 6SM4 | 2014-05-15 13:16:46 Mapping NZD-201406-GLOBEX to 6NM4. Service code: cme | 2014-05-15 13:16:46 SC Exchange Data - Starting real-time market data updates for: 6NM4 | 2014-05-15 13:16:46 Mapping MXP-201406-GLOBEX-USD to 6MM4. Service code: cme | 2014-05-15 13:16:46 SC Exchange Data - Starting real-time market data updates for: 6MM4 | 2014-05-15 13:16:46 IB: Requesting historical order fills for account DU137835 | 2014-05-15 13:16:47 Interactive Brokers: Received Open orders end message. | 2014-05-15 13:16:47 HD Request # 3 - Requesting Intraday data. Start Date-Time: 2014-05-15 13:16:07. Record interval: 1 . Symbol: E7M4 | 2014-05-15 13:16:47 HD Request # 3 - Decompressing data. | 2014-05-15 13:16:47 HD Request # 3 - Receiving Intraday data for E7-201406-GLOBEX-USD starting at 2014-05-15 13:16:07 | 2014-05-15 13:16:47 HD Request # 3 - Timestamp of first Intraday data file record written: 2014-05-15 13:16:07 | 2014-05-15 13:16:47 Socket has been shutdown and closed. | 2014-05-15 13:16:47 The network socket for historical data has been closed. | 2014-05-15 13:16:47 HD Request # 3 - Received 2 records from 2014-05-15 13:16:07 to 2014-05-15 13:16:33 (26.0 seconds) and wrote 2 records for E7-201406-GLOBEX-USD | 2014-05-15 13:16:47 HD Request # 3 - Intraday download COMPLETE for E7-201406-GLOBEX-USD. Completion time: 1s | 2014-05-15 13:16:47 Real-time Intraday chart data file updates started for E7-201406-GLOBEX-USD | 2014-05-15 13:16:47 HD Request # 4 - Downloading Intraday chart data for M6E-201406-GLOBEX to the file M6E-201406-GLOBEX.scid. Service: cme | 2014-05-15 13:16:47 HD Request # 4 - Download start Date-Time: 2014-05-15 13:16:21.0 | 2014-05-15 13:16:47 HD Request # 4 - Using server: scdf1.sierracharts.com port 10149 | 2014-05-15 13:16:47 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-05-15 13:16:47 The network socket is connected. | 2014-05-15 13:16:47 HD Request # 4 - Sending historical data logon request message. | 2014-05-15 13:16:47 HD Request # 4 - Requesting Intraday data. Start Date-Time: 2014-05-15 13:16:21. Record interval: 1 . Symbol: M6EM4 | 2014-05-15 13:16:47 HD Request # 4 - Decompressing data. | 2014-05-15 13:16:47 HD Request # 4 - Receiving Intraday data for M6E-201406-GLOBEX starting at 2014-05-15 13:16:21 | 2014-05-15 13:16:47 HD Request # 4 - Timestamp of first Intraday data file record written: 2014-05-15 13:16:21 | 2014-05-15 13:16:47 Socket has been shutdown and closed. | 2014-05-15 13:16:47 The network socket for historical data has been closed. | 2014-05-15 13:16:47 HD Request # 4 - Received 1 record from 2014-05-15 13:16:21 to 2014-05-15 13:16:21 (0.0 seconds) and wrote 1 record for M6E-201406-GLOBEX | 2014-05-15 13:16:47 HD Request # 4 - Intraday download COMPLETE for M6E-201406-GLOBEX. Completion time: 0s | 2014-05-15 13:16:47 Real-time Intraday chart data file updates started for M6E-201406-GLOBEX | 2014-05-15 13:16:47 HD Request # 5 - Downloading Intraday chart data for JPY-201406-GLOBEX to the file JPY-201406-GLOBEX.scid. Service: cme | 2014-05-15 13:16:47 HD Request # 5 - Download start Date-Time: 2014-05-15 13:16:23.0 | 2014-05-15 13:16:47 HD Request # 5 - Using server: scdf2.sierracharts.com port 10149 | 2014-05-15 13:16:47 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-05-15 13:16:47 The network socket is connected. | 2014-05-15 13:16:47 HD Request # 5 - Sending historical data logon request message. | 2014-05-15 13:16:47 HD Request # 5 - Requesting Intraday data. Start Date-Time: 2014-05-15 13:16:23. Record interval: 1 . Symbol: 6JM4 | 2014-05-15 13:16:47 HD Request # 5 - Decompressing data. | 2014-05-15 13:16:47 HD Request # 5 - Receiving Intraday data for JPY-201406-GLOBEX starting at 2014-05-15 13:16:23 | 2014-05-15 13:16:47 HD Request # 5 - Timestamp of first Intraday data file record written: 2014-05-15 13:16:23 | 2014-05-15 13:16:48 Socket has been shutdown and closed. | 2014-05-15 13:16:48 The network socket for historical data has been closed. | 2014-05-15 13:16:48 HD Request # 5 - Received 11 records from 2014-05-15 13:16:23 to 2014-05-15 13:16:55 (32.0 seconds) and wrote 11 records for JPY-201406-GLOBEX | 2014-05-15 13:16:48 HD Request # 5 - Intraday download COMPLETE for JPY-201406-GLOBEX. Completion time: 1s | 2014-05-15 13:16:48 Real-time Intraday chart data file updates started for JPY-201406-GLOBEX | 2014-05-15 13:16:48 HD Request # 6 - Downloading Intraday chart data for J7-201406-GLOBEX-USD to the file J7-201406-GLOBEX-USD.scid. Service: cme | 2014-05-15 13:16:48 HD Request # 6 - Download start Date-Time: 2014-05-15 13:15:00.0 | 2014-05-15 13:16:48 HD Request # 6 - Using server: scdf1.sierracharts.com port 10149 | 2014-05-15 13:16:48 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-05-15 13:16:48 The network socket is connected. | 2014-05-15 13:16:48 HD Request # 6 - Sending historical data logon request message. | 2014-05-15 13:16:48 HD Request # 6 - Requesting Intraday data. Start Date-Time: 2014-05-15 13:15:00. Record interval: 1 . Symbol: J7M4 | 2014-05-15 13:16:48 HD Request # 6 - Decompressing data. | 2014-05-15 13:16:48 HD Request # 6 - Receiving Intraday data for J7-201406-GLOBEX-USD starting at 2014-05-15 13:15:00 | 2014-05-15 13:16:48 HD Request # 6 - Timestamp of first Intraday data file record written: 2014-05-15 13:15:00 | 2014-05-15 13:16:48 Socket has been shutdown and closed. | 2014-05-15 13:16:48 The network socket for historical data has been closed. | 2014-05-15 13:16:48 HD Request # 6 - Received 1 record from 2014-05-15 13:15:00 to 2014-05-15 13:15:00 (0.0 seconds) and wrote 1 record for J7-201406-GLOBEX-USD | 2014-05-15 13:16:48 HD Request # 6 - Intraday download COMPLETE for J7-201406-GLOBEX-USD. Completion time: 0s | 2014-05-15 13:16:48 Real-time Intraday chart data file updates started for J7-201406-GLOBEX-USD | 2014-05-15 13:16:48 HD Request # 7 - Downloading Intraday chart data for GBP-201406-GLOBEX to the file GBP-201406-GLOBEX.scid. Service: cme | 2014-05-15 13:16:48 HD Request # 7 - Download start Date-Time: 2014-05-15 13:16:22.0 | 2014-05-15 13:16:48 HD Request # 7 - Using server: scdf2.sierracharts.com port 10149 | 2014-05-15 13:16:48 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-05-15 13:16:48 The network socket is connected. | 2014-05-15 13:16:48 HD Request # 7 - Sending historical data logon request message. | 2014-05-15 13:16:48 HD Request # 7 - Requesting Intraday data. Start Date-Time: 2014-05-15 13:16:22. Record interval: 1 . Symbol: 6BM4 | 2014-05-15 13:16:48 HD Request # 7 - Decompressing data. | 2014-05-15 13:16:48 HD Request # 7 - Receiving Intraday data for GBP-201406-GLOBEX starting at 2014-05-15 13:16:22 | 2014-05-15 13:16:48 HD Request # 7 - Timestamp of first Intraday data file record written: 2014-05-15 13:16:22 | 2014-05-15 13:16:48 Socket has been shutdown and closed. | 2014-05-15 13:16:48 The network socket for historical data has been closed. | 2014-05-15 13:16:48 HD Request # 7 - Received 9 records from 2014-05-15 13:16:22 to 2014-05-15 13:16:54 (32.0 seconds) and wrote 9 records for GBP-201406-GLOBEX | 2014-05-15 13:16:48 HD Request # 7 - Intraday download COMPLETE for GBP-201406-GLOBEX. Completion time: 0s | 2014-05-15 13:16:48 Real-time Intraday chart data file updates started for GBP-201406-GLOBEX | 2014-05-15 13:16:48 HD Request # 8 - Downloading Intraday chart data for M6B-201406-GLOBEX-USD to the file M6B-201406-GLOBEX-USD.scid. Service: cme | 2014-05-15 13:16:48 HD Request # 8 - Download start Date-Time: 2014-05-15 13:13:41.0 | 2014-05-15 13:16:48 HD Request # 8 - Using server: scdf1.sierracharts.com port 10149 | 2014-05-15 13:16:48 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-05-15 13:16:48 The network socket is connected. | 2014-05-15 13:16:48 HD Request # 8 - Sending historical data logon request message. | 2014-05-15 13:16:48 HD Request # 8 - Requesting Intraday data. Start Date-Time: 2014-05-15 13:13:41. Record interval: 1 . Symbol: M6BM4 | 2014-05-15 13:16:48 HD Request # 8 - Decompressing data. | 2014-05-15 13:16:48 HD Request # 8 - Receiving Intraday data for M6B-201406-GLOBEX-USD starting at 2014-05-15 13:13:41 | 2014-05-15 13:16:48 HD Request # 8 - Timestamp of first Intraday data file record written: 2014-05-15 13:13:41 | 2014-05-15 13:16:48 Socket has been shutdown and closed. | 2014-05-15 13:16:48 The network socket for historical data has been closed. | 2014-05-15 13:16:48 HD Request # 8 - Received 1 record from 2014-05-15 13:13:41 to 2014-05-15 13:13:41 (0.0 seconds) and wrote 1 record for M6B-201406-GLOBEX-USD | 2014-05-15 13:16:48 HD Request # 8 - Intraday download COMPLETE for M6B-201406-GLOBEX-USD. Completion time: 0s | 2014-05-15 13:16:48 Real-time Intraday chart data file updates started for M6B-201406-GLOBEX-USD | 2014-05-15 13:16:48 HD Request # 9 - Downloading Intraday chart data for AUD-201406-GLOBEX to the file AUD-201406-GLOBEX.scid. Service: cme | 2014-05-15 13:16:48 HD Request # 9 - Download start Date-Time: 2014-05-15 13:16:22.0 | 2014-05-15 13:16:48 HD Request # 9 - Using server: scdf2.sierracharts.com port 10149 | 2014-05-15 13:16:48 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-05-15 13:16:48 The network socket is connected. | 2014-05-15 13:16:48 HD Request # 9 - Sending historical data logon request message. | 2014-05-15 13:16:48 HD Request # 9 - Requesting Intraday data. Start Date-Time: 2014-05-15 13:16:22. Record interval: 1 . Symbol: 6AM4 | 2014-05-15 13:16:48 HD Request # 9 - Decompressing data. | 2014-05-15 13:16:48 HD Request # 9 - Receiving Intraday data for AUD-201406-GLOBEX starting at 2014-05-15 13:16:22 | 2014-05-15 13:16:48 HD Request # 9 - Timestamp of first Intraday data file record written: 2014-05-15 13:16:22 | 2014-05-15 13:16:48 Socket has been shutdown and closed. | 2014-05-15 13:16:48 The network socket for historical data has been closed. | 2014-05-15 13:16:48 HD Request # 9 - Received 5 records from 2014-05-15 13:16:22 to 2014-05-15 13:16:53 (31.0 seconds) and wrote 5 records for AUD-201406-GLOBEX | 2014-05-15 13:16:48 HD Request # 9 - Intraday download COMPLETE for AUD-201406-GLOBEX. Completion time: 0s | 2014-05-15 13:16:49 Real-time Intraday chart data file updates started for AUD-201406-GLOBEX | 2014-05-15 13:16:49 HD Request # 10 - Downloading Intraday chart data for M6A-201406-GLOBEX-USD to the file M6A-201406-GLOBEX-USD.scid. Service: cme | 2014-05-15 13:16:49 HD Request # 10 - Download start Date-Time: 2014-05-15 13:15:56.0 | 2014-05-15 13:16:49 HD Request # 10 - Using server: scdf1.sierracharts.com port 10149 | 2014-05-15 13:16:49 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-05-15 13:16:49 The network socket is connected. | 2014-05-15 13:16:49 HD Request # 10 - Sending historical data logon request message. | 2014-05-15 13:16:49 HD Request # 10 - Requesting Intraday data. Start Date-Time: 2014-05-15 13:15:56. Record interval: 1 . Symbol: M6AM4 | 2014-05-15 13:16:49 HD Request # 10 - Decompressing data. | 2014-05-15 13:16:49 HD Request # 10 - Receiving Intraday data for M6A-201406-GLOBEX-USD starting at 2014-05-15 13:15:56 | 2014-05-15 13:16:49 HD Request # 10 - Timestamp of first Intraday data file record written: 2014-05-15 13:15:56 | 2014-05-15 13:16:49 Socket has been shutdown and closed. | 2014-05-15 13:16:49 The network socket for historical data has been closed. | 2014-05-15 13:16:49 HD Request # 10 - Received 1 record from 2014-05-15 13:15:56 to 2014-05-15 13:15:56 (0.0 seconds) and wrote 1 record for M6A-201406-GLOBEX-USD | 2014-05-15 13:16:49 HD Request # 10 - Intraday download COMPLETE for M6A-201406-GLOBEX-USD. Completion time: 0s | 2014-05-15 13:16:49 Real-time Intraday chart data file updates started for M6A-201406-GLOBEX-USD | 2014-05-15 13:16:49 HD Request # 11 - Downloading Intraday chart data for CAD-201406-GLOBEX to the file CAD-201406-GLOBEX.scid. Service: cme | 2014-05-15 13:16:49 HD Request # 11 - Download start Date-Time: 2014-05-15 13:16:23.0 | 2014-05-15 13:16:49 HD Request # 11 - Using server: scdf2.sierracharts.com port 10149 | 2014-05-15 13:16:49 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-05-15 13:16:49 The network socket is connected. | 2014-05-15 13:16:49 HD Request # 11 - Sending historical data logon request message. | 2014-05-15 13:16:49 HD Request # 11 - Requesting Intraday data. Start Date-Time: 2014-05-15 13:16:23. Record interval: 1 . Symbol: 6CM4 | 2014-05-15 13:16:49 HD Request # 11 - Decompressing data. | 2014-05-15 13:16:49 HD Request # 11 - Receiving Intraday data for CAD-201406-GLOBEX starting at 2014-05-15 13:16:23 | 2014-05-15 13:16:49 HD Request # 11 - Timestamp of first Intraday data file record written: 2014-05-15 13:16:23 | 2014-05-15 13:16:49 Socket has been shutdown and closed. | 2014-05-15 13:16:49 The network socket for historical data has been closed. | 2014-05-15 13:16:49 HD Request # 11 - Received 4 records from 2014-05-15 13:16:23 to 2014-05-15 13:16:43 (20.0 seconds) and wrote 4 records for CAD-201406-GLOBEX | 2014-05-15 13:16:49 HD Request # 11 - Intraday download COMPLETE for CAD-201406-GLOBEX. Completion time: 0s | 2014-05-15 13:16:49 Real-time Intraday chart data file updates started for CAD-201406-GLOBEX | 2014-05-15 13:16:49 HD Request # 12 - Downloading Intraday chart data for CHF-201406-GLOBEX to the file CHF-201406-GLOBEX.scid. Service: cme | 2014-05-15 13:16:49 HD Request # 12 - Download start Date-Time: 2014-05-15 12:59:13.0 | 2014-05-15 13:16:49 HD Request # 12 - Using server: scdf1.sierracharts.com port 10149 | 2014-05-15 13:16:49 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-05-15 13:16:49 The network socket is connected. | 2014-05-15 13:16:49 HD Request # 12 - Sending historical data logon request message. | 2014-05-15 13:16:49 HD Request # 12 - Requesting Intraday data. Start Date-Time: 2014-05-15 12:59:13. Record interval: 1 . Symbol: 6SM4 | 2014-05-15 13:16:49 HD Request # 12 - Decompressing data. | 2014-05-15 13:16:49 HD Request # 12 - Receiving Intraday data for CHF-201406-GLOBEX starting at 2014-05-15 12:59:13 | 2014-05-15 13:16:49 HD Request # 12 - Timestamp of first Intraday data file record written: 2014-05-15 12:59:13 | 2014-05-15 13:16:49 Socket has been shutdown and closed. | 2014-05-15 13:16:49 The network socket for historical data has been closed. | 2014-05-15 13:16:49 HD Request # 12 - Received 181 records from 2014-05-15 12:59:13 to 2014-05-15 13:16:52 (17.6 minutes) and wrote 181 records for CHF-201406-GLOBEX | 2014-05-15 13:16:49 HD Request # 12 - Intraday download COMPLETE for CHF-201406-GLOBEX. Completion time: 0s | 2014-05-15 13:16:49 Real-time Intraday chart data file updates started for CHF-201406-GLOBEX | 2014-05-15 13:16:49 HD Request # 13 - Downloading Intraday chart data for MSF-201406-GLOBEX-USD to the file MSF-201406-GLOBEX-USD.scid. Service: cme | 2014-05-15 13:16:49 HD Request # 13 - Download start Date-Time: 2014-05-15 13:16:18.0 | 2014-05-15 13:16:49 HD Request # 13 - Using server: scdf2.sierracharts.com port 10149 | 2014-05-15 13:16:49 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-05-15 13:16:49 The network socket is connected. | 2014-05-15 13:16:49 HD Request # 13 - Sending historical data logon request message. | 2014-05-15 13:16:49 HD Request # 13 - Requesting Intraday data. Start Date-Time: 2014-05-15 13:16:18. Record interval: 1 . Symbol: 6SM4 | 2014-05-15 13:16:49 HD Request # 13 - Decompressing data. | 2014-05-15 13:16:49 HD Request # 13 - Receiving Intraday data for MSF-201406-GLOBEX-USD starting at 2014-05-15 13:16:18 | 2014-05-15 13:16:49 HD Request # 13 - Timestamp of first Intraday data file record written: 2014-05-15 13:16:18 | 2014-05-15 13:16:49 Socket has been shutdown and closed. | 2014-05-15 13:16:49 The network socket for historical data has been closed. | 2014-05-15 13:16:49 HD Request # 13 - Received 11 records from 2014-05-15 13:16:18 to 2014-05-15 13:16:52 (34.0 seconds) and wrote 11 records for MSF-201406-GLOBEX-USD | 2014-05-15 13:16:49 HD Request # 13 - Intraday download COMPLETE for MSF-201406-GLOBEX-USD. Completion time: 0s | 2014-05-15 13:16:49 Real-time Intraday chart data file updates started for MSF-201406-GLOBEX-USD | 2014-05-15 13:16:49 HD Request # 14 - Downloading Intraday chart data for NZD-201406-GLOBEX to the file NZD-201406-GLOBEX.scid. Service: cme | 2014-05-15 13:16:49 HD Request # 14 - Download start Date-Time: 2014-05-15 13:15:52.0 | 2014-05-15 13:16:49 HD Request # 14 - Using server: scdf1.sierracharts.com port 10149 | 2014-05-15 13:16:49 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-05-15 13:16:49 The network socket is connected. | 2014-05-15 13:16:50 HD Request # 14 - Sending historical data logon request message. | 2014-05-15 13:16:50 HD Request # 14 - Requesting Intraday data. Start Date-Time: 2014-05-15 13:15:52. Record interval: 1 . Symbol: 6NM4 | 2014-05-15 13:16:50 HD Request # 14 - Decompressing data. | 2014-05-15 13:16:50 HD Request # 14 - Receiving Intraday data for NZD-201406-GLOBEX starting at 2014-05-15 13:15:52 | 2014-05-15 13:16:50 HD Request # 14 - Timestamp of first Intraday data file record written: 2014-05-15 13:15:52 | 2014-05-15 13:16:50 Socket has been shutdown and closed. | 2014-05-15 13:16:50 The network socket for historical data has been closed. | 2014-05-15 13:16:50 HD Request # 14 - Received 1 record from 2014-05-15 13:15:52 to 2014-05-15 13:15:52 (0.0 seconds) and wrote 1 record for NZD-201406-GLOBEX | 2014-05-15 13:16:50 HD Request # 14 - Intraday download COMPLETE for NZD-201406-GLOBEX. Completion time: 1s | 2014-05-15 13:16:50 Real-time Intraday chart data file updates started for NZD-201406-GLOBEX | 2014-05-15 13:16:50 HD Request # 15 - Downloading Intraday chart data for MXP-201406-GLOBEX-USD to the file MXP-201406-GLOBEX-USD.scid. Service: cme | 2014-05-15 13:16:50 HD Request # 15 - Download start Date-Time: 2014-05-15 13:16:00.0 | 2014-05-15 13:16:50 HD Request # 15 - Using server: scdf2.sierracharts.com port 10149 | 2014-05-15 13:16:50 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-05-15 13:16:50 The network socket is connected. | 2014-05-15 13:16:50 HD Request # 15 - Sending historical data logon request message. | 2014-05-15 13:16:50 HD Request # 15 - Requesting Intraday data. Start Date-Time: 2014-05-15 13:16:00. Record interval: 1 . Symbol: 6MM4 | 2014-05-15 13:16:50 HD Request # 15 - Decompressing data. | 2014-05-15 13:16:50 HD Request # 15 - Receiving Intraday data for MXP-201406-GLOBEX-USD starting at 2014-05-15 13:16:00 | 2014-05-15 13:16:50 HD Request # 15 - Timestamp of first Intraday data file record written: 2014-05-15 13:16:00 | 2014-05-15 13:16:50 Socket has been shutdown and closed. | 2014-05-15 13:16:50 The network socket for historical data has been closed. | 2014-05-15 13:16:50 HD Request # 15 - Received 1 record from 2014-05-15 13:16:00 to 2014-05-15 13:16:00 (0.0 seconds) and wrote 1 record for MXP-201406-GLOBEX-USD | 2014-05-15 13:16:50 HD Request # 15 - Intraday download COMPLETE for MXP-201406-GLOBEX-USD. Completion time: 0s | 2014-05-15 13:16:50 Real-time Intraday chart data file updates started for MXP-201406-GLOBEX-USD | 2014-05-15 13:16:50 Reloading all charts with filename: CHF-201406-GLOBEX.scid | 2014-05-15 13:17:46 HD Request # 16 - Downloading Intraday chart data for CHF-201406-GLOBEX to the file CHF-201406-GLOBEX.scid. Service: cme | 2014-05-15 13:17:46 HD Request # 16 - Download start Date-Time: 2013-11-10 13:17:46.0 | 2014-05-15 13:17:46 HD Request # 16 - Using server: scdf1.sierracharts.com port 10149 | 2014-05-15 13:17:46 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-05-15 13:17:46 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Matrix Live-SIM\Data\CHF-201406-GLOBEX.scid | 2014-05-15 13:17:46 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Matrix Live-SIM\Data\CHF-201406-GLOBEX.scid | 2014-05-15 13:17:46 The network socket is connected. | 2014-05-15 13:17:46 HD Request # 16 - Sending historical data logon request message. | 2014-05-15 13:17:46 HD Request # 16 - Requesting Intraday data. Start Date-Time: 2013-11-10 13:17:46. Record interval: 1 . Symbol: 6SM4 | 2014-05-15 13:17:46 HD Request # 16 - Decompressing data. | 2014-05-15 13:17:46 HD Request # 16 - Receiving Intraday data for CHF-201406-GLOBEX starting at 2013-12-03 16:34:55 | 2014-05-15 13:17:46 HD Request # 16 - Timestamp of first Intraday data file record written: 2013-12-03 16:34:55 | 2014-05-15 13:17:46 Socket has been shutdown and closed. | 2014-05-15 13:17:47 The network socket for historical data has been closed. | 2014-05-15 13:17:47 HD Request # 16 - Received 183595 records from 2013-12-03 16:34:55 to 2014-05-15 13:17:55 (162.9 days) and wrote 183595 records for CHF-201406-GLOBEX | 2014-05-15 13:17:47 HD Request # 16 - Intraday download COMPLETE for CHF-201406-GLOBEX. Completion time: 1s | 2014-05-15 13:17:47 Real-time Intraday chart data file updates started for CHF-201406-GLOBEX | 2014-05-15 13:17:47 |
[2014-05-15 17:08:50] |
The problem is now resolved. Update the symbol settings as explained here: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
