Date/Time: Sun, 05 May 2024 17:27:09 +0000
Data Delayed
View Count: 502
[2021-12-15 22:31:07] |
User401229 - Posts: 14 |
My data is delayed by 10 mins I have package 11 How do I connect to my amp trading account Please help Thanks |
[2021-12-15 23:38:47] |
What futures trading/brokerage service do you use? For the reason why we ask this question, refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges (Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-16 16:48:08] |
I have an account with AMP futures
[2021-12-16 18:16:06] |
John - SC Support - Posts: 31379 |
Are you setup with CQG or Rithmic for your order routing with your AMP account?
[2021-12-16 21:04:32] |
cqg on my amp account. order routing only
[2021-12-16 21:10:09] |
which option do i need to select in the date/trade services window?
[2021-12-16 21:59:15] |
You need to go through the following Setup Instructions to connect your Sierra Chart to your CQG account: CQG Trading Platform Service: Setup Instructions After you make this change, then open your Chartbooks and select Edit >> Translate Symbols to Current Service. You should be all good after this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
