Date/Time: Sat, 19 Sep 2026 12:39:42 +0000
Spreadsheet programming question - FRACTIME
View Count: 1387
[2021-12-04 20:07:01]
User183724 - Posts: 194
I have a 5 minute chart with a spreadsheet study.
In column AN, I have this formula
=FRACTIME(A3)-FRACTIME(A4). I'm looking for the difference between the last two FRACTIMES.
Im getting the following results:
0.00347222222222221 row 3
0.00347222222222221 row 4
0.003472222210648135 <========= ...
0.003472222233796285 <=========
0.00347222222222221
0.00347222222222221
0.003472222222222321 <=========
0.00347222222222221
0.00347222222222221
0.00347222222222221
0.00347222222222221
0.00347222222222221
0.00347222222222221
0.00347222222222221
0.00347222222222221 appears to me to be the 'correct' answer and those 'hiccups' are where the sheet updates. I understand they are double float numbers and will be slightly different based on updates.
Could someone with better math skills please explain just how long the updates take and maybe a little on the time keeping in general.
Ive read all I can find on time keeping including the following but cant quite make sense of it.
Spreadsheet Functions: Serial DateTime Values
Spreadsheet Example Formulas and Usage
thx tim
[2021-12-04 22:34:52]
Sawtooth - Posts: 4354
Column A is the bar's Open timestamp, so on a 5 min chart, the difference is always going to be 5 min.
0.003472222222222222 is 5 min (300 sec) in SerialDateTime
5/1440 = 0.003472222222222222
300/86400 = 0.003472222222222222
If you want to compare the current bar's Open time to the current intrabar time, use J41:
=FRACTIME($J$41)-FRACTIME(A3)
Or you could use the Bar Time Duration study.
[2021-12-06 16:19:07]
John - SC Support - Posts: 47939
The results you see that are not quite "perfect" is due to floating point error. Refer to the following:
Working with Spreadsheets: Floating-Point Values and Comparisons When Using the Spreadsheet Study
