Date/Time: Tue, 15 Jul 2025 18:49:41 +0000
Higher priced stock charts performance issue
View Count: 587
[2021-11-25 13:21:52] |
User975545 - Posts: 3 |
Hello, everyone! I'm having an issue with chart performance. Scrolling is too slow in AMZN, TSLA, GOOGL, etc. Everything is fine with stocks under 1000 dollars. I can put any amount of studies on a chart of stock under 1000 dollars, everything is perfect. I've done everything recommended here https://www.sierrachart.com/index.php?page=doc/helpdetails30.html. Didn't help. Thank you in advance. |
[2021-11-25 14:05:42] |
Refer to help topic 30.23: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.23 - Chart Tick Size and Volume at Price Processing Also 30.34: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.34 - TPO Profile Chart Letter/Block Price Increment / Volume by Price Ticks Per Volume Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
