Date/Time: Fri, 06 Nov 2026 09:02:51 +0000
Unable to Flatten/Reverse. Position does not exist.
View Count: 1265
[2021-11-15 21:28:00]
User751739 - Posts: 29
I have a hotkey set for flatten and cancel and sometimes when I try to flatten I get. It seems I have to click the hotkey twice for it to actually flatten. It is not a order size issue w/ the broker, because I had less that half the allotted size.
ESZ1.CME[M] #45 | User order entry | Unable to Flatten/Reverse. Position does not exist. Working non-market orders will be canceled | Symbol: ESZ1.CME | TradeAccount: * | 2021-11-15 12:31:02.952 *
ESZ1.CME[M] #45 | User order entry | Unable to Flatten/Reverse. Position does not exist. Working non-market orders will be canceled | Symbol: ESZ1.CME | TradeAccount: * | 2021-11-15 12:36:54.770 *
ESZ1.CME[M] #45 | User order entry | Unable to Flatten/Reverse. Position does not exist. Working non-market orders will be canceled | Symbol: ESZ1.CME | TradeAccount: * | 2021-11-15 12:40:42.708 *
TradeActivity files query time: 0.005559 seconds. Entries: 6. Current queries: 1 | 2021-11-15 12:48:06.487
TradeActivity files query time: 0.000420 seconds. Entries: 6. Current queries: 1 | 2021-11-15 12:48:06.541
TradeActivity files query time: 0.000688 seconds. Entries: 6. Current queries: 1 | 2021-11-15 12:48:06.593
TradeActivity files query time: 0.000598 seconds. Entries: 6. Current queries: 2 | 2021-11-15 12:48:06.594
TradeActivity files query time: 0.000978 seconds. Entries: 6. Current queries: 1 | 2021-11-15 12:48:07.032
TradeActivity files query time: 0.000533 seconds. Entries: 6. Current queries: 1 | 2021-11-15 12:48:07.054
TradeActivity files query time: 0.000603 seconds. Entries: 6. Current queries: 1 | 2021-11-15 12:48:07.113
TradeActivity files query time: 0.000613 seconds. Entries: 6. Current queries: 1 | 2021-11-15 12:48:07.404
TradeActivity files query time: 0.000621 seconds. Entries: 6. Current queries: 1 | 2021-11-15 12:48:07.529
I also tried enabling: Global Trade Settings Windows: Hold Market Order Until Pending Cancel Orders Are Confirmed (Global Settings >> General Trade Settings >> General), but it didn't seem to make a difference
[2021-11-15 22:18:34]
The message you are getting:
Is saying that you do not have an open position, therefore there is nothing to flatten. Hitting the Flatten button again (or hotkey for Flatten) should not have any effect, except to give you the same message again.
Are you sure those messages are not from the second time you try to flatten, where the position is already closed by the first Flatten command?
[2021-11-15 23:59:34]
thank you for the quick response. It is the message I saw while my order was still opened. At least the first instance.
[2021-11-16 01:23:57]
There is a difference between an open Order and a Position.
You need to examine the Trade Activity Log for any other information about the orders or positions:
Trade Activity Log: Viewing Historical Trade Activity
You have all of the information on your side and you should consult with your broker for further help.
