Date/Time: Fri, 06 Nov 2026 08:40:04 +0000
Sudden Rithmic Data Connection Issue
View Count: 1320
[2021-10-31 10:06:46]
User130077 - Posts: 10
Hi On Friday my Rithmic data suddenly failed and I am now getting a constant waiting to reconnect message in the top left area of the screen.
Previously I had no issues and this just suddenly happened the whole rest of the month I have been connected without issue
I had to log onto my back up R trader and use the DOM.
I have downloaded the Bridge files as thought this might be the issue, but I don't seem to have a RIM folder in my sierra chart that I can find. I assume something must have changed Friday and wondered what I can do. or if anyone else has had this issue best stuart
[2021-10-31 15:42:59]
There were connectivity problems to Rithmic on Friday and Rithmic has resolved this.
If you still have a problem Sunday evening, you can post the Message Log and we can look.
Connect to the data feed:
Select "File >> Disconnect"
Select "File >> Connect to Data Feed"
Date Time Of Last Edit: 2021-10-31 15:43:20
[2021-10-31 22:13:27]
Thats all sorted thank you for the fast response
