Date/Time: Fri, 18 Jul 2025 23:01:07 +0000
P&L Incorrecte
View Count: 581
[2021-10-21 06:34:12] |
CorbinAntoine - Posts: 5 |
Hello, I just noticed that the P&L on Sierra Chart is incorrect. Or even on my charts the DPL or NPL is at 0 when it should not be. I am using Profit/Lost Text and the Closed PL calculation is incorrect. How can I solve the problem. Please note that - The software version is 2320 - I have also tried the manipulations that you have suggested for the same problem for other people. - I use CQG. Thank you. |
[2021-10-21 09:37:25] |
Sierra_Chart Engineering - Posts: 20254 |
Refer to: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
