Date/Time: Sun, 05 May 2024 08:57:41 +0000
My calc lines are moving with the price.
View Count: 359
[2021-10-20 15:15:29] |
User228382 - Posts: 3 |
All my calc lines are moving prior day high prior day close,midpoint and open. can you tell me how to fix? |
[2021-10-20 15:26:17] |
John - SC Support - Posts: 31362 |
What do you mean by "calc lines"? If these are drawn lines, then refer to the following: Lines/Rays or Other Chart Drawings Move After Drawing Them If these are part of a study (i.e. they are Subgraph data), then what study are you using and what exactly is changing? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-21 08:32:56] |
Hi John, Yes this is a study. Its the OHLC ( its the prior day open ,High ,low,and close. Never had this hppen before. I happened with the last rollover. |
[2021-10-21 13:21:18] |
Please get us a copy of that chart with just the one study on it for which you are having the problem. We will take a look and see if we can reproduce what you are seeing and figure out what is happening. Follow these instructions to get us your chartbook: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
