Date/Time: Mon, 29 Apr 2024 00:47:32 +0000
Sierra Chart with TT feed problem
View Count: 1680
[2013-04-24 02:47:20] |
toews&kane - Posts: 209 |
This is what's happening the TT feed has been working fine until today. DF:gets stuck and only moves once every minute (now it's at 56) If I disconnect and reconnect to the data feed, changes immediately appears Also there's no market depth (bid/ask) see uploaded file |
Capture.PNG / V - Attached On 2013-04-24 02:46:47 UTC - Size: 91.71 KB - 582 views |
[2013-04-24 05:06:35] |
Please contact your broker about this. You are using the correct symbol. This is a problem with the FIX Adapter you are connected to or an authorization on your account. For reference, refer to help topic 3.4 here: http://www.sierrachart.com/index.php?l=doc/helpdetails3.html#h3.4 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
