Date/Time: Sat, 12 Jul 2025 00:57:20 +0000
shortcut for
View Count: 1137
[2021-10-18 18:53:00] |
HumblyTrading - Posts: 204 |
Hello, I have scrolled a number of times through all of the available shortcut keys (which is a great feature of SC). However, I do not see an option to assign a shortcut to the command "Allow Copy to other charts." I would like a shortcut key to uncheck this for certain objects more rapidly than having to go into the context menu. Could you please advise me on how to do this? Thank you very much! Mike T |
[2021-10-18 23:42:51] |
John - SC Support - Posts: 40857 |
There is not a shortcut key for that option. We have marked this as a Feature Request.
[2021-10-19 01:44:59] |
Thank you, For now, I'll use keyboard maestro (on Mac), or AHK (Windows) as a woarkaround. Mike T |
[2021-11-22 19:52:08] |
amirN - Posts: 159 |
I cannot find the shortcut though according to your documentation it must be there.
[2021-11-23 15:15:50] |
It is there to be added to the Drawing Shortcut Menu, which means that it gets added to the right-click options when you have a drawing. To add this, refer to the following: Global Settings Menu: Customize Chart Drawing Menu (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-11-23 15:33:50] |
My mistake, I was trying to add it to the chart shortcut menu. One final question; can I customise the colours in the "Drawing Shortcut Menu":Color ? |
[2021-11-24 15:27:03] |
Refer to the following: Chart Drawing Tools: Customizing Colors on the Menu For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-04 15:36:42] |
Hello SC Team, I wonder if there is any estimate on adding this shortcut key? I would use it 100 times per day at least! :) Thanks! Mike |
[2024-05-17 01:18:14] |
Hello again SC Team, I'm hoping this feature request may be on the radar in the not too distant future? I appreciate all the constant improvements in SierraChart! Mike |
[2024-08-07 19:56:27] |
Hello John and Team, May I ask if this feature is possibly on the list for a future update? If not, I will develop an alternative thorough a hot key program such as AHK. Thank you as alway, Mike |
[2024-08-07 20:11:34] |
We take all requests, but we can not say when we would get to any particular item. In this case, we would say that you should not wait for this to get implemented by us. If you can find another way to do it, then you should pursue that option. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-08 08:27:55] |
Thank you
