Date/Time: Tue, 07 May 2024 21:14:05 +0000
Trade multiple accounts simultaneously
View Count: 2846
[2021-10-14 12:14:27] |
Daniel Widmar - Posts: 24 |
Hey Guys, Is it possible to connect a funded account for example Topsteptrader with an amp futures account and trade these accounts simultaneously? So when i open a position with the funded account the same position executes in the amp account and vice versa? thanks |
[2021-10-14 14:21:22] |
John - SC Support - Posts: 31440 |
No, it is not possible to do this with different brokers. Refer to the information at the following link for what is available in terms of trading multiple accounts with the same trades: Order Allocation to Trade Accounts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-25 10:51:31] |
Hey, can i trade multiple funded accounts simultaneously? So when i open a position with one funded account the same position executes in the other funded accounts. Funded Accounts from Leeloo, Data Feed Rithmic. thanks for your Help |
[2021-10-25 11:00:47] |
If you will be using this feature: Order Allocation to Trade Accounts You can use this feature with those trading accounts, only if those trading accounts are all on the same username that you are connected to Rithmic with. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-25 11:01:23
