Date/Time: Sun, 05 May 2024 12:30:43 +0000
TD Ameritrade
View Count: 592
[2021-10-13 14:12:46] |
Ilana416 - Posts: 5 |
Hello, I have a trading account with TD Ameritrade (which is why I need Sierra chart for charting and Denali for data). TD Ameritrade is not a listed as a supported trading service. Is there any other way to verify that I have a live trading account as required to get the non-professional fee structure? Also, what data is collected from my account when I connect to a trading service (any supported service) for validation purposes? Thanks in advance! Ilana Date Time Of Last Edit: 2021-10-15 01:35:23
[2021-10-13 15:17:55] |
John - SC Support - Posts: 31362 |
We do not have support for TD Ameritrade. Therefore, you would have to have an account with another service that is supported. We recommend the following service as a way to have an account for a small outlay that will work for the CME Group: Easy Solution to CME Funded Trading Account Requirement With regards to what data is collected when you connect to a trading service, we will have to look into that and get back to you. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-13 15:44:35] |
Thank you, I will look into opening an account with either of those brokers. Can you please advise regarding the second question I had? - what account information is checked/cross checked? Is it just checking for a live account or are more details checked? Ilana |
[2021-10-15 01:34:08] |
Sierra_Chart Engineering - Posts: 14230 |
There is no data that is collected: Also, what data is collected from my account when I connect to a trading service (any supported service) for validation purposes? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
