Date/Time: Thu, 02 May 2024 07:39:34 +0000
hand
View Count: 382
[2021-10-13 07:27:32] |
User313942 - Posts: 17 |
hi , the hand function not work . the hande only move chart left / right . up / down moving no work . what a resone ?
[2021-10-13 14:10:43] |
John - SC Support - Posts: 31293 |
You need to set the setting that allows the hand to move Up/Down. Refer to the following: Chart Drawing Tools: Vertical Movement and Scaling For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
