Date/Time: Fri, 03 May 2024 06:23:46 +0000
HSI on HKEX Delayed Data
View Count: 446
[2021-10-13 01:46:22] |
mjackson34 - Posts: 11 |
My data is delayed for Hang Seng futures, not Osaka exchange though. How do I fix this issue?
[2021-10-13 13:49:44] |
John - SC Support - Posts: 31334 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
