Date/Time: Tue, 07 May 2024 03:32:46 +0000
CHN50 Intraday Chart
View Count: 451
[2021-10-12 17:35:36] |
User551515 - Posts: 4 |
Hi, I'm new. When I try to open Intraday chart on CHN50 CFD the chart is not loaded (The screen remains all black). But if I try to load Intraday chart on NAS100 CFD the chart is loaded properly. So I don't think I'm doing something wrong with the procedure, as otherwise I would have not been able to open NAS100 either. How do you suggest I can load the CHN50 chart, please? |
[2021-10-12 17:48:19] |
Basically I realized that for NAS100 the data file is downloaded by sierra chart. For CHN50 the data file is not downloaded. How to fix this, please? |
screenshot.jpg / V - Attached On 2021-10-12 17:47:53 UTC - Size: 84.35 KB - 110 views |
[2021-10-12 18:32:27] |
John - SC Support - Posts: 31419 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-12 19:36:05] |
Software version: 2319 64-bit | 2021-10-12 19:33:02.603 Primary Thread ID: 7540 | 2021-10-12 19:33:02.603 Usage end date: 2021-10-26 | 2021-10-12 19:33:02.603 Usage time has ended. Sierra Chart is in Free mode. Features are restricted. | 2021-10-12 19:33:02.603 To purchase usage time, select 'Help >> Add Usage Credit' on the menu. | 2021-10-12 19:33:02.603 * Allow Support for Sierra Chart Data Feeds is enabled. | 2021-10-12 19:33:02.603 Current selected Data/Trading service: SC Data - All Services | 2021-10-12 19:33:02.603 Custom symbol settings values: enabled | 2021-10-12 19:33:02.603 Chart Update Interval: 500 | 2021-10-12 19:33:02.603 Intraday Data Storage Time Unit: 1 | 2021-10-12 19:33:02.603 Time Zone: +00:00:00 (UTC+00) | 2021-10-12 19:33:02.603 2021-10-12 19:33:02 Local computer time in UTC | 2021-10-12 19:33:02.603 2021-10-12 19:33:02 Local computer time in SC Time Zone | 2021-10-12 19:33:02.603 2021-10-12 19:31:41 Server time in UTC | 2021-10-12 19:33:02.603 Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-10-12 19:33:02.603 Program path: C:\SierraChart2\ | 2021-10-12 19:33:02.603 Data Files path: C:\SierraChart2\Data\ | 2021-10-12 19:33:02.603 OS Version Number: 6.3 | 2021-10-12 19:33:02.604 Locale Setting: C | 2021-10-12 19:33:02.604 DLLs: UserContributedStudies_64.dll | 2021-10-12 19:33:02.604 Allowed protected custom studies: | 2021-10-12 19:33:02.604 Connect to Data Feed | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2021-10-12 19:33:56.388 * |
[2021-10-13 00:07:23] |
Your account was restricted since you tried to login using an older account of yours. We have reset your trial for the account Ke******03. Please ensure that you only use that account on that computer, or you will lock yourself out again.
[2021-10-13 05:09:38] |
Ok, thank you. I appreciate that. With Sierra Standard package will I be able to access intraday historical data of all CFD (see screenshot)? |
[2021-10-13 10:03:54] |
Yes this is correct.
