Date/Time: Sun, 05 May 2024 21:44:46 +0000
Possible to Copy Drawings across charts, but limit to specific timeframe visibility?
View Count: 709
[2021-10-12 14:03:06] |
HumblyTrading - Posts: 170 |
Hello, I draw many objects on my charts as I make them up for homework, live trading, etc. I also have several different timeframes open at the same time, such as Daily, 4Hr, 1Hr, 15m, 5m, 50Tick. One of my favorite features in Sierra is how seamlessly and quickly you can modify drawings in various windows, and the changes are reflected across all of the other charts. However, I would like to limit certain objects to only display on higher time frames and other objects to only display on lower timeframes. For example, it would be wonderful to be able to write some text objects on the Tick 30, click on those text objects, and set their visibility to something like "Only display on timeframes less than 5 mins." Is there a potential way to do this in SierraChart? Thank you for any support or ideas, Mike |
[2021-10-12 16:41:38] |
John - SC Support - Posts: 31379 |
There is not a way to do this in Sierra Chart. We have marked this as a Feature Request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-13 04:54:13] |
Would it be possible at least to add functionality to certain objects for "Do Not Copy This Object"? Perhaps that would be an easier remedy for the time-being? Thank you for your program and continued support! Mike T |
[2021-10-13 14:09:41] |
This exists. Refer to the following: Copying Chart Drawings from Other Charts Automatically: Preventing Specific Chart Drawings from Being Copied For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-13 16:15:21] |
Awesome! That solves my problem! :) |
