Date/Time: Sat, 18 May 2024 16:33:07 +0000
Problem to start a trade
View Count: 299
[2021-10-11 16:35:31] |
User452962 - Posts: 4 |
I have a funded account with AMP and I am a non-professional. I use Sierra. i have the denali feed. The dates from Denali are shown in the Sierra. Problem: When opening a position, Sierra activates the Sim mode. |
[2021-10-11 16:39:02] |
ich habe ein finanziertes Konto bei AMP. Ich nutze Sierra. Denali DAtenfeed. Problem: beim Eröffnen eines Trades / Position schaltet Sierra in den Sim-Modus. ENGLISCH I have a funded account with AMP. I use Sierra. Denali data feed. Problem: when opening a trade / position, Sierra switches to Sim mode. |
[2021-10-11 16:55:32] |
You are not connected to your account with AMP. Your setting for Global Settings >> Data/Trade Service Settings >> Current Selected Service is set to SC Data - All Services, therefore the only option is to trade in Simulation Mode, which is why the system keeps putting you back into that mode. You need to setup your system to connect to your AMP account. To do this you will need to follow the appropriate instructions depending on what order routing service AMP has you setup to use. For CQG, follow these instructions: CQG Trading Platform Service: Setup Instructions For Rithmic, follow these instructions: Rithmic Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
