Date/Time: Sat, 18 May 2024 15:25:01 +0000
intraday data
View Count: 335
[2021-10-11 16:11:42] |
User740715 - Posts: 26 |
I am using rithmic with the paper trading server and I can no longer load the intraday data or it is incomplete what should I do to be able to load the intraday data
[2021-10-11 16:44:36] |
If you are referring to historical intraday data (i.e. not the real-time data updating) then that is an issue with the Rithmic data. The only solution is to use the Denali Exchange Data Feed instead. Refer to the information here: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
