Date/Time: Sat, 18 May 2024 17:29:57 +0000
My chart do not update after receive error memory full message
View Count: 322
[2021-10-11 15:38:51] |
tptrader - Posts: 16 |
I receive an error message say something about memory full and it stop update the chart. I deleted file in my hard drive to have more memory and update Sierra chart to Version 2315 64-bit (39212). shut down computer, restart and my chart still not update. I think the file get corrupted and not update. please help. I have account with AMP and I think they are using CQG data. Do I need to ask them to change the data to Delina? Thank you
[2021-10-11 16:30:13] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
