Date/Time: Sat, 18 May 2024 23:29:58 +0000
connection broker
View Count: 346
[2021-10-11 15:29:36] |
User452962 - Posts: 4 |
How can I do that Connection: SierraChart (Denali data feed) with AMP produce ? Best regards |
[2021-10-11 16:18:32] |
Sorry, but we are not understanding the question? If you are asking how you can use Sierra Chart with AMP, then it depends on what order routing service you are setup with at AMP. You can be setup with either Rithmic or CQG. Refer to the following instructions on how to setup your Sierra Chart to the appropriate service: For CQG, follow these instructions: CQG Trading Platform Service: Setup Instructions For Rithmic, follow these instructions: Rithmic Trading Platform Service: Setup Instructions -------- To get real-time data from us for the CME Group, the follow these instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* If you want real-time data for the EUREX or CFE exchanges, then those instructions are on the same page as the CME Group, just scroll to the top of the page to find the link to the appropriate exchanges instructions. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
