Date/Time: Fri, 06 Nov 2026 08:17:22 +0000
Duplicate Chart to Chartbook command not working
View Count: 771
| [2021-09-23 16:21:10] |
| User832913 - Posts: 14 |
The "Duplicate Chart to Chartbook" command is no longer working and neither is the "Duplicate All Charts to Chartbook". I get an unfamiliar window that pops up showing information that doesn't work and I've never seen before. I installed the latest version of SA in an attempt to resolve it but it's still doing the same thing. Thanks in advance for your assistance. I'm attaching a screenshot. |
| [2021-09-23 16:29:53] |
Left click twice, in the Value column to the right of Chartbooks(List) to see the drop-down list of the Chartbooks.
| [2021-09-23 17:01:35] |
| John - SC Support - Posts: 48449 |
Refer to the information on how to work with that particular window item here: Settings Windows Interface: Item List (Working with Sierra Chart Windows >> Selection Specific Options) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
