Date/Time: Sun, 05 May 2024 17:22:11 +0000
Daily TPO chart not updating
View Count: 446
[2021-09-22 03:55:39] |
User918591 - Posts: 20 |
Hello, My daily TPO chart has suddently stopped to update itself automatically. I have to close sierra chart the chart and open it again for the TPO to update. This is not the first time it happens. The last time I had to complete close the TPO chart and create another one. What is the solution to sort this problem out? Find attached the screen shot. Regards, |
image_2021-09-22_055518.png / V - Attached On 2021-09-22 03:55:21 UTC - Size: 38.64 KB - 113 views |
[2021-09-22 13:03:41] |
User907968 - Posts: 802 |
Roll forwards to Z contract, V barely has any volume.
[2021-09-22 13:57:11] |
This is never a solution and will make no difference: I have to close sierra chart the chart and open it again for the TPO to update. This is not the first time it happens. The last time I had to complete close the TPO chart and create another one.
What is the solution to sort this problem out? If there is a problem with the data feed itself you can reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers However, you should be using the December contract for GC. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
