Date/Time: Sun, 19 May 2024 14:15:18 +0000
FTSE 100 FUTURES
View Count: 980
[2021-08-15 05:09:52] |
Stav - Posts: 104 |
Can you tell me where I can access the delayed ftse-100 futures data. They were previously on Liffe/Euronext. Thanks. |
[2021-08-16 16:17:54] |
John - SC Support - Posts: 31715 |
It is still in the LIFFE exchange under the symbol "Z".
[2021-08-19 19:32:30] |
You can access historical data for the symbols for this exchange. Refer to: Sierra Chart Historical Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-19 19:32:46
[2024-03-30 13:48:38] |
OriolCasas - Posts: 155 |
30.03.2024 This should be in eurex by now right? I can't find it, under which name it is? Thank you |
[2024-03-30 16:18:41] |
User584084 - Posts: 241 |
https://www.eurex.com/ex-en/markets/idx/ftse/ftse-100/FTSE-100-Index-Futures-2593796
[2024-03-30 16:51:19] |
I mean in Denali data, in Sierra Chart
[2024-04-01 13:39:22] |
You need to select "File >> Find Symbol" and find the symbol you are looking for in that window. We can not say what exactly the symbol name is, as we do not know what Trading Service you are connected to. Each service uses a different symbology. Refer to the following: File Menu: Find Symbol (File) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
