Date/Time: Fri, 20 Nov 2026 02:01:55 +0000
Using Sierrachart without broker
View Count: 1313
| [2021-08-08 04:03:12] |
| franfevetrade - Posts: 3 |
Hi, i would like to know if i can use SierraChart platform without a broker. I mean, i would like to use SierraChart platform with EUREX real time data just to do analysis, follow the market in real time and play some demo. Is it possible if i buy service package 10? Thank you very much for your attention
| [2021-08-09 06:28:17] |
Yes this is all supported. You will need service package 10. Payment instructions are below. The instructions for real-time EUREX data are here: Denali Exchange Data Feed We have activated your account for one week at package 12 for now. You can start with the Delayed Exchange Data Feed: Delayed Exchange Data Feed Follow these instructions to add usage time to your Sierra Chart account: 1. Select "Help >> Account Control Panel" on the Sierra Chart software menu. On the displayed webpage, click on "Activate Services". Or you can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password. 2. Choose the particular Service Package that you want to automatically renew and press the "Update/Set" button. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-09 06:29:07
| [2021-08-25 06:48:28] |
Thank you very much for your support. The answer was really clear. There is any possibility to activate my account at package 12 with delayed exchange data feed (EUREX) for another extra week? I had no time to check it in a proper way and this extra time would be really helpful to me. Thanks again.
| [2021-08-25 11:21:36] |
This is now done. Make sure you are also running the current version of Sierra Chart. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
