Date/Time: Wed, 18 Nov 2026 07:18:49 +0000
Real-time data
View Count: 680
| [2021-07-29 22:24:27] |
| User941285 - Posts: 2 |
Hello, I have no real-time data for futures, it's delayed 15m although I have Denali feed and Full CME Group (CME, CBOT, COMEX, NYMEX) for nonprofessional Trading account. Thanks for checking. best regards, Stefan |
| [2021-07-29 22:48:17] |
The reason you are not getting real-time data from the CME Group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified in the last month that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees. Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees If you do not have a funded trading account or one with a supported trading service, then refer to this solution: Easy Solution to CME Funded Trading Account Requirement We recommend using the above solution in any case to avoid this problem in the future. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
