Date/Time: Thu, 02 May 2024 19:34:47 +0000
Can i get some help...
View Count: 410
[2021-07-28 16:06:27] |
Youngtradr - Posts: 2 |
i cant figure out why my sessions are not working they are set up for NYSE but the 30 minute periods arent starting on the hour they are starting at 9:40 instead of 9:30 and there is no where that tells how to fix it i would love some help figuring it out
[2021-07-28 16:32:49] |
58LesPaul - Posts: 429 |
This may be the issue Chart Session Times: Bar Starting Times |
[2021-07-28 20:28:08] |
This is controlled by the Session Times >> Start Time. Refer to: Chart Session Times: Bar Starting Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-28 20:28:28
