Date/Time: Tue, 07 May 2024 03:45:05 +0000
horizontal lines for price ranges
View Count: 388
[2021-07-26 16:03:53] |
User645832 - Posts: 99 |
is there an indicator I could use to draw extended horizontal lines at the low and high of a specific period bar even the chart uses different period bars? e.g. on a 15 min chart draw lines at the low and high of the 1 min bar of 16:00 if not, what is the easiest way to achieve that? |
[2021-07-26 19:10:42] |
John - SC Support - Posts: 31419 |
You would need to have 2 charts. One set to 1 minute and the other to 15 minute bars. Then on the 1 minute chart, use the High/Low For Time Period - Extended and setup that study as you desire. Then use the Study/Price Overlay on the 15 minute chart to overlay the High/Low for Time Period - Extended from the 1 minute chart to the 15 minute chart. Refer to the following for the High/Low for Time Period - Extended study: High/Low for Time Period - Extended Refer to the following for the Study/Price Overlay study: Study/Price Overlay Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
