Date/Time: Fri, 03 May 2024 18:14:26 +0000
How to Apply Globally an Old Study's New Setting to all the various Studies where used?
View Count: 354
[2021-07-26 14:20:22] |
User14953 - Posts: 193 |
Recently the Parameter "Number Of Days To Calculate" is changed to "3 Days", (Chart Studies >Study settings pivot points -Daily). What is the Easiest way to Apply that Parameter Globally to all 44 instances of this Study Setting inside the various Chart Studies where it is used? |
[2021-07-26 17:48:33] |
John - SC Support - Posts: 31355 |
If the charts are linked to have the same studies, then you would just update the one and all others would update. Refer to the following for more information on this: Chart Settings: Chart Linking (Chart >> Chart Settings >> Linking menu) Otherwise, there is not an easy way to update them all the same time. You would have to go to each one and change it. To make things a little easier, if all the settings are the same, then you could make the change the Default Settings so you could just remove and then add the study back with the updated settings. Refer to the following: Chart Studies: Using Custom Default Study Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
