Date/Time: Sun, 05 May 2024 17:52:07 +0000
Zoom out horizontally and vertically
View Count: 885
[2021-07-25 17:47:58] |
orbit777 - Posts: 6 |
Hello, I want to be able to see the chart zoom out both on Y and X axis . Now when I want to look on larger times I have limitation . How do I zoom to perceive a larger view? The current method of decreasing bar space isnt working for my needs. I’m looking for something similar to the TOS platform option. |
Attachment Deleted. |
[2021-07-25 17:57:08] |
cmet - Posts: 537 |
1. Right click in the scale on right side of chart and select "Set X & Y Constant Relationship" 2. Left click and drag on timeline at bottom of chart to scale in and out |
[2021-07-26 06:42:08] |
Refer to: Working With Charts: Zooming In and Out Chart Scale and Scale Adjusting: X & Y Constant Relationship Scaling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
