Date/Time: Sun, 05 May 2024 19:46:15 +0000
Replay Chart dialogue not showing/Simulation Trade Service not working
View Count: 382
[2021-07-24 18:25:42] |
UserCD - Posts: 7 |
1. Just "normal" simulation - replay button dialogue not showing at all - i.e. no response. 2. When following instructions to start the simulated futures trading service - Simulated Futures Trading Service: Setup Instructions - I do not get the ability to select the "Use Enhanced Trade Simulation Service" as it does not show in the row below Service Settings nor is there any ability to make a selection. 3. Despite issue in item 2 above I managed to create a new account and continued on to setting data to "Sc- All Data" but still replay chart did not work on a new chart with updated symbol. 3. Love the platform have been a user for several years but totally confused about simulating trades - this is an important aspect of my trading routines and would appreciate any assistance in getting his fixed asap. |
Enhanced Trade Simulation Service Missing.PNG / V - Attached On 2021-07-24 18:17:30 UTC - Size: 16.08 KB - 153 views |
[2021-07-24 22:48:11] |
1. Refer to: Replaying Charts: Chart Replay Window Not Visible 2. There is no longer a need for this setting and it is removed. Just make sure you are running an up-to-date version of Sierra Chart: Software Download: Fast Update 3. If you are using SC Data-All Services, any account you create on the Trading Evaluator is not used and not relevant. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-07-25 07:59:20] |
UserCD - Posts: 7 |
Followed advice and got it all sorted now - thx.
