Date/Time: Sun, 28 Apr 2024 05:17:03 +0000
Direct Order Routing Service and AMP Futures?
View Count: 3890
[2021-07-22 22:42:27] |
User344276 - Posts: 65 |
Once the Sierra Chart direct order routing service becomes available will it work for those of us that are still with AMP Futures?
[2021-07-23 09:18:48] |
We have avoided answering this question. We do not want to say what clearing firms we are working with, and will not, but this currently does not include AMP. We cannot go into further detail about this now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-23 09:19:06
[2021-07-23 22:38:10] |
ondafringe - Posts: 248 |
That is unfortunate for all of us AMP customers. Don't get to switch to SC's CME Direct Routing... and don't regain access to the Web-Based Portal, either. Makes me wonder: Is it SC not wanting to work with AMP? Or AMP not wanting to work with SC? After all, you had (what appeared to be) a good working relationship with them in the past. Too bad. |
[2021-07-23 22:53:43] |
Makes me wonder: Is it SC not wanting to work with AMP? Or AMP not wanting to work with SC? It is more a case, that we have an easier path and dramatically easier path, and an assisted path, with other clearing firms to get this released. But the initial release is not going to be with AMP and whether it becomes available there, we do not know. That is not our focus right now because we have to focus on the firms/brokers willing/wanting to work with us. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-23 22:56:03
[2021-07-25 00:03:10] |
User13668 - Posts: 291 |
For those of us with AMP, will we still be able to trade via CQG order routing after you implement your own direct order routing? |
[2021-07-25 09:31:41] |
DF52 - Posts: 19 |
Looking ahead I really hope SC and AMP are able to work together. I want to use the SC order routing but I do NOT wish to change brokers. Appreciate that this needs effort from AMP as well as from SC.
[2021-07-25 22:49:33] |
Regarding post #5, yes, although gradually from September to the end of the year there will be a requirement to use CME and EUREX data from our own data feeds instead of CQG. Looking ahead I really hope SC and AMP are able to work together. I want to use the SC order routing but I do NOT wish to change brokers. Appreciate that this needs effort from AMP as well as from SC.
We will see how this progresses.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-25 22:49:54
[2021-07-27 07:24:14] |
I'm also hoping Sierra Chart and AMP can work together. I have used Sierra Chart for quite some time because it has good usability. And I like what AMP offers as a broker and would rather stay with them. I've looked at the other brokers and decided to stay with AMP.
[2021-08-04 00:25:10] |
What do they have that other brokers do not? I've looked at the other brokers and decided to stay with AMP.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-04 00:25:25
[2021-08-04 05:12:01] |
I like AMP's margins. I have looked into other brokers and it appears AMP has the lowest margins which of course has pros and cons.
Date Time Of Last Edit: 2021-08-04 05:39:06
[2021-08-04 05:36:23] |
Sierra_Chart Engineering - Posts: 14111 |
Yes, that is true, and that is not something that other brokers are willing to match. It exposes them to unnecessary risks.
[2021-08-29 07:11:58] |
At this time, are you able to state the clearing firms you are currently working with and if AMP is one of them? If you are still not able to comment on this, when will information become available? Thank you.
[2021-08-29 10:45:06] |
58LesPaul - Posts: 429 |
Clearing house and brokerage firm for futures
