Date/Time: Fri, 03 May 2024 16:35:16 +0000
help with retriveing data
View Count: 382
[2021-07-20 17:21:17] |
coachted - Posts: 286 |
i am running a custom study and would like to know if I can get the custom study data as well as price downloaded into an excel spreadsheet
[2021-07-21 04:05:56] |
Yes you can do this. You will want to use this command: Edit Menu: Edit >> Export Bar and Study Data to Text File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
