Date/Time: Sat, 04 May 2024 03:34:20 +0000
Numbers Bars calcualted values
View Count: 596
[2021-07-16 08:03:42] |
User138457 - Posts: 36 |
Dear Support, is there a way to have numbers bars calcuated values display delta%? I.E. delta/(total volume) thanks in advance |
[2021-07-16 18:51:19] |
John - SC Support - Posts: 31362 |
We will see if we can get to this soon. But it will be at least 3 weeks just due to other items we have to get done first.
[2022-03-25 21:42:15] |
As we were beginning to work on this we found that this already exists in the original Numbers Bars Calculated Values as the Subgraph named Ask Volume Bid Volume Difference Percent. Refer to the information in this section: Numbers Bars: Numbers Bars Calculated Values Subgraph Descriptions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-27 01:35:15] |
User19165 - Posts: 346 |
Renaming this to be "delta percent" as the OP suggested would be a lot more intuitive to us traders. When we look for the delta, that is what we look for. That is the trader terminology. Not "ask volume - bid volume". Seemingly small points such as this goes a long way to improving product usability to your target market. Date Time Of Last Edit: 2022-03-27 01:36:01
