Date/Time: Sun, 05 May 2024 21:38:21 +0000
value area lines
View Count: 1223
[2021-07-15 18:40:24] |
coachted - Posts: 286 |
I know there is a way to add value area lines to a chart but there a way they can be dynamice like a ema line that way the user can track the developing value area...please see an example attached
sc valare developing.png / V - Attached On 2021-07-15 18:39:48 UTC - Size: 239.97 KB - 316 views |
[2021-07-15 19:04:35] |
John - SC Support - Posts: 31379 |
Use the Volume Value Area Lines study and set the Input for Draw Developing Area Lines to Yes. Refer to the information here: Volume Value Area Lines For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-07-15 20:52:04] |
thank you thats exactly wehat i was looking for
[2021-07-30 12:59:58] |
User531256 - Posts: 3 |
Hi, I was wondering how to remove connecting lines of the VALUE AREA LINES indicator. I only want the lines to display during the day sessions and not connect sessions together. The TPO VALUE AREA LINES do it perfectly (No connecting Lines between Sessions). I also have the same problem with the STUDY SUBGRAPHS AVERAGE that I use as a midpoint for the High/Low for Time Period Indicator. The connecting lines between sessions only show up when I squeeze the price bars together. It only allows me to see one session of Value Area lines at a time. I need to squeeze the price bars to see more Value Areas from days ago. Is there any way to remove the connecting lines or is there is alternative way to achieve this? Thanks JS |
Attachment Deleted. |
[2021-07-30 13:27:08] |
58LesPaul - Posts: 429 |
Is Draw Zeros set to no?
[2021-07-30 15:52:10] |
Hi it does not have that option in settings. I'm using the Volume Value Area Lines study, not Volume by Price. Thanks |
[2021-08-02 09:06:11] |
Refer to: Chart Studies: Avoiding Vertical Joining Line for Study Subgraphs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
